rotating cam gear?
Old Mar 12, 2009 | 02:24 PM
j0keefe21's Avatar
Default rotating cam gear?
with the head off the car should i be able to rotate the cam with my hands with the valve springs and everything still on it?
Old Mar 12, 2009 | 04:53 PM
j0keefe21's Avatar
Default Re: rotating cam gear?
its a pretty general question i just dont know how i am sopposed to turn it to get the timing right. because i cant turn it right now with my hands.
Old Mar 12, 2009 | 05:20 PM
newtron63h's Avatar
use a wrench to turn it. when you install, make sure #1 piston is at TDC and #1 valves are closed, this way you wont be bending any valves. then use a wrench on the cam gear to fine tune the cam when lining it up with the crank
Old Mar 12, 2009 | 11:08 PM
j0keefe21's Avatar
thanks i was just worried bc i couldnt turn it with my hand
underpressure02
Sep 19, 2009 09:20 PM
JDM_SOHC
84
Sep 6, 2009 09:36 AM
DMCCOY
12
Jan 9, 2009 08:39 PM
superstock2
Sep 10, 2006 05:56 AM
CPR
Jan 20, 2006 09:06 PM
