ek parts and b-series parts etc...
96-00 civic power doors white mint all power inside 100.00
96-00 civic power door panels w/ switches clean not broke 60.00
96-00 civic floor harness for power doors 50.00
96-98 civic ac boxes all that are for ac that go behind dash 40.00
96-00 civic ac lines perfect shape the two that go to the fire wall 25.00
96-00 civic aftermarket mount kit i dunno what brand120.00
96-00 civic sub frame w rack and pinion and power steering line w pump all in perfect working order and b-series pump 40.00
96-00 transmission mount bracket 20.00
96-00 civic manual pedal assembly with master cylinder and fluid resivoir 60.00
96-00 civic wiper assembly w wiper cowl cover 30.00
b series edelbrock 65mm throttle body 150.00
b series eagle rods used one needs some reconditioning from machine shop or get one new one will still be cheaper then buying whole set 100.00
b series 4-1 race header i dunno what brand but its real nice header 120.00
b series half shafts one is male end one is female 40.00 each
b series axles both in good shape 50 for both
b20 head perfect shape less than 50 thousand on it 50.00
b series valve cover freshly powder coated wrinkle red very nice 80.00 or 40 and your old valve cover and ill change it for you
b series non-vtech obd2 distributer 60.00
94-01 jdm integra type r cluster 120.00
94-01 integra pedal assembly 40.00
98GSR-Turbo
Mar 31, 2011 07:39 AM
