WTB broken GSR B16 type r transmissions
looking to buy any b series trannys you have lying around collecting dust
GSR B16 ITR YS1
cable or hydro does not matter
grinds, popouts broken cases, busted diffs, bearings making noise whatever
if there is something salvageable i will most likely want it
let me know asking price and location
GSR B16 ITR YS1
i have a hydro ls tranny if u intrested diff broke and broke tranny case all the gears are good no grinds but the shafts like fell out on my garage floor so idk whats what but i just want it gone so 50 bucks and its urs located in joppa md 21085
i got a b16 hydro trans with a cracked case but worked great but when it got low on fluid it would pop out of fifth just pm me an offer and we can work some thing out
i got a s4c that is missing the diff and ring gear, the countershaft bearing where the snapring is is broken, the pinion gear is missing a tooth and the synchro sleeves are done. the drive gears on the mainshaft and countershaft are all in good shape as well as the actual synchros. im located in 19446 but can meetup around philly/wilmington area if i get close to my asking price. looking to get $140
do you mean the case is messed up, when you said where the snapring is is broken?
i cant justify spending that much if the case is damaged too
pretty much just the gears are good from what you are saying
i have a usdm short geared ys1 cable trans, out of a 92 db2 gsr, stock 1st-4th gears with an ls 5th gear, it grinds and pops out of 3rd, lmk if your interested, i do want to get rid of it but i dont want to give it away because its a nice setup, i miss having it in my car. Im stuck with an ls trans mated to a b16, long gearing ftl, anyways lmk
i want this one
let me know a price
I have a jdm gsr trans , still in car that is start to give me issue , im thinkin 3rd and 4th gear sycros .....shoot me a p.m and we can see whats up.
got a gsrtrans that the diff broke i think.... the mainshaft will spin but not the diff.... also have a gsr trans with a third gear grind lmk if intrested
