HELP del sol climate control
Old Mar 12, 2009 | 11:51 AM
mxjosh's Avatar
Default HELP del sol climate control
anyone know how to take out the del sol climate control to switch the bulbs
i already took out the console with the shift boot...took out the cd player...took off the ***** for it....and there is a screw under the control it looks like but i cant get the sob undone...all i keep doin is strippin it..anyone no if i even need to take that screw out or if there are any others?
Old Mar 14, 2009 | 08:30 AM
mxjosh's Avatar
Default Re: HELP del sol climate control
no del sol owners?
Old Mar 14, 2009 | 11:57 AM
joelmatt89's Avatar
yes you need to take that screw out. I don't have a clue why it is there i didn't put mine back in. Once you get that screw out you will have to disconnect the cables by the foot wells. Then you will be able to pull it out a little bit. For me the worst part is always unplugging the connectors every time i have done it it takes me about 30 minutes to unplug both of them. I usually start with the yellow on and sort of pry the plastic holding it with a screw driver then for the green one i press the button with the screw driver and pry it out from there. I can never get them out if I just press them with my fingers, just keep trying if you cant get it and remember that pulling harder won't do a thing but give you more troubles.
Old Jan 5, 2010 | 09:35 PM
Rat_Bear's Avatar
Where are the two screws in the front?
Brice.Hayden
Jan 5, 2007 04:05 PM
Groove_D
Dec 3, 2006 12:57 AM
Out of every "game"
Jan 7, 2006 08:49 PM
bryphotoguy
Jan 5, 2006 09:42 AM
cdizzle
Jul 5, 2005 12:00 AM
