Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Free shipping on ALL SKUNK2 Products!
Old Mar 12, 2009 | 09:56 AM
Flatirons Performance's Avatar
Default Free shipping on ALL SKUNK2 Products!
Flatirons Performance is an Authorized Skunk2 E-Tailer, and we are currently offering free gound shipping on all Skunk2 Products from Cam Seals all the way up to exhausts that are ordered through our web-site.
Here is a link to all the Skunk2 Products that are listed on our web-site
Or you can brouse for parts for your car by clicking the menue on the left of the screen.
We will also do our best to match any advertized price, so if you see any Skunk2 products for less, let us know and we will take care of you.
Here are some of the more popular parts that we have in stock:
New! SKUNK2 LIMITED EDITION, FLAT-BLACK REAR LOWER CONTROL ARMS
Capitalizing on their already popular forged aluminum Rear Lower Control Arms, Skunk2 is proud to introduce the ultimate in stealth suspension modifications – Skunk2’s limited edition, Black Series, hard-anodized Rear Lower Control Arms. Each limited edition Black Series Rear Lower Control Arm features Skunk2’s signature black look in an anodized coating and is serialized for authenticity. This exclusive run is currently available for the ’92-’95 Civic, ’96-’00 Civic, and ’94-’01 Integra and is paired with red, low-deflection, polyurethane bushings for the ultimate contrast (black bushings sold separately).
Click here to get yours while supplies last! Currently in stock for the 1996 - 2000 Civic - $229.99
Skunk2 Mega Power Header for the 2006+ Civic SI
The Skunk2 MegaPower Header is designed and engineered to maximize exhaust flow and increase both horsepower and torque throughout the entire RPM powerband. Skunk2's unique design is the result of over a decade of racing experience coupled with computerized modeling and extensive dyno testing.
Each Skunk2 MegaPower Header features equal length, sequentially-paired, stepped primaries and a 4-2-1 Tri-Y design with a 2.5 inch collector. These features coupled with their unique design specs provide an extremely broad powerband that can be used on a wide range of engine sizes and configurations. Each header is constructed from T-304 stainless steel with fully polished, mandrel-bent tubing and a CNC-machined flange for added strength and durability.
Fits the 06+ Civic SI
Skunk2 Part # 412-05-0930
Click Here to order your Skunk2 Mega Power Header for the 2006+ Civic SI - $799.99
Skunk2 Composite Fuel Rails
Skunk2 introduces its new series of composite intake manifolds and fuel rails. Skunk2’s new composite components are made using a proprietary casting process, from a carbon reinforced aerospace thermo-polymer composite that is 33% lighter, 60% stronger, and runs up to 100ºF cooler than aluminum. Keeping the air and fuel cooler results in a significant increase in horsepower and torque. This composite is also chemical resistant to all types of fuels including alcohol.
Skunk2’s new cutting-edge composite fuel rails are made using their proprietary carbon impregnated aerospace thermo-polymer composite. This material insulates the fuel from both radiant and conductive heat transfer under the hood. Keeping the fuel cooler results in an increase in horsepower and torque. Skunk2 has seen power gains of up to 3% in real world testing.
Skunk2 composite fuel rails feature a large 0.625” internal bore with radius inlets to the injectors thus improving flow characteristics. This type of radius injector inlet design is not possible with extruded and drilled aluminum fuel rails (which have sharp angles internally where the main bore meets the injector bores).
Skunk2 fuel rails can be used with factory fuel lines and fuel regulators.
Up to 3% Gain Just by Keeping Fuel Cooler
-8 AN End Threads with 0.625" Internal Bore
Can Support Up to 1200HP
Can Be Used with Stock Fuel System
Chemical Resistant to All Fuels including Alcohol
Click here to order your Skunk2 Fuel Rail - $189.99
Skunk2 K-Series 70mm Throttle Body
Designed to be used with an OEM or Skunk2 Intake Manifold, the Skunk2 Pro-Series Throttle Body will help increase horsepower and torque by optimizing airflow to your engine. A larger throttle body is important to making additional power throughout the entire rev range on modified engines that have higher airflow requirements than stock. The Skunk2 Pro Series Throttle Body features a 70mm bore and results in increases up to 8+hp throughout the power band on naturally aspirated applications (even more should be gained on forced induction applications).
Skunk2 went through an extensive design and testing process to produce a unit that not only provides more flow, but also retains the smooth drivability of the OEM unit. The Skunk2 Pro-Series Throttle Body is designed using the latest CAE (Computer Aided Engineering) tools to produce a unit that exceeds industry standards. Each Pro-Series Throttle Body is CNC-machined from billet 6061-T6 aluminum and hard anodized for added durability. Skunk2's throttle pulley design allows for smooth movement and throttle modulation, while the coolant hoses have been eliminated for cooler operation.
The Skunk2 Pro Series Throttle Body will directly bolt up to the OEM PRB intake manifold and will work on RBC manifolds with an adapter plate.
• High Flowing Large Bore Capable Of Supporting 1000 HP
• Gains As High As 50+ HP On Forced Induction Applications
• Durable and Corrosion Resistant Hard Anodized Finish
• Uses Factory Throttle Cable
• CNC Forged AL6061-T6 Billet Aluminum
• Sealed Bearings For Smooth Operation
• MAP Sensor Relocated To Bottom side For Cleaner Look
• Eliminates Factory Waterlines For Cooler Operation
Click here to order your Skunk2 70mm Throttle Body - $369.99
Skunk2 Intake Manifolds
Skunk2 Racing’s Pro-Series Intake Manifold improves airflow thus increasing horsepower by as much as 8% over stock manifolds on stock engines and even more on modified or forced-induction engines. Skunk2 manifolds significantly increase horsepower between 3000-8800 rpm; the broadest powerband increase in the industry, and the new Pro-Series design features a 22% increase in power over the previous design.
Engineered with a larger plenum and tapered runners, Skunk2 manifolds increase and accelerate airflow, and are designed to increase the effects of wave scavenging at the engine’s optimum operating RPM range providing a broad overall increase in usable power. Each runner entry is also modified to balance airflow between cylinders. Oversized throttle bodies can be used as a result of the modified IAC opening on the flange.
Like OEM factory manifolds, Skunk2 manifolds are shell molded and CNC machined, to achieve superior strength, high-quality finish, and a precise fit. Each manifold is vacuum tested to ensure quality and leakfree operation.
The Skunk2 Pro-Series manifold utilizes all stock sensors and auxiliaries for a simple bolt-on installation that delivers maximum power. Ideal for NA and Forced Induction.
Skunk2 Has Been Leading the Sport Compact Car Industry with Cast Aluminum Manifolds Since 2000:
- Increased Plenum and Runner Size
- Oversized Throttle Body Opening
- Made From High-Grade 356 Aluminum
- OEM Quality Shell Molded Casting
- Nitrous Mounting Bungs
- Skunk2 Acid-Etched Nameplate
- Broadest Usable Powerband
- Vacuum Tested To Ensure Quality
- Utilizes Stock Sensors 64mm Throttle Body Opening That Can Be Port - Matched To 75mm
- Increased Plenum Volume
- 8” Tapered Runners For Maximum Torque and Power Increase
- CARB EO Approved
Computational Fluid Dynamics (CFD): is one of the branches of fluid mechanics that uses numerical methods and algorithms to solve and analyze problems that involve fluid flows. Computers are used to perform the millions of calculations required to simulate the interaction of fluids and gases with the complex surfaces used in engineering.
Click here to order your Skunk2 Intake Manifold - $259.99
Skunk2 5 & 6 Speed Shift *****
Skunk2's Shift **** celebrates excellence. Features laser-etched Skunk2 logo.
Don't be fooled by cheap imitations of real Skunk2 shift *****! Only Skunk2 shift ***** feature a PVD titantium finish that resists scratching, and are precision CNC machined to exacting manufacturing standards.
Skunk2 Shift ***** are custom-weighted to over 400-grams and designed to be used in conjunction with the Skunk2 Racing Short-Throw Shift Levers. The added weight of the shift **** helps promote smoother and more positive shifting. This combination provides the ultimate in positive shift engagement for high-performance drag, road racing and street applications.
The Skunk2 Racing Shift **** also provides a great enhancement to any shift lever application with a 10 x 1.5 thread pitch 5 speed application.
Click here to order your Skunk2 5-Speed Shift ****
Click here to order your Skunk2 6-Speed Shift ****
Skunk2 Single and Dual bend Short Shifters
Skunk2 Racing short shifters are constructed from high-strength alloy steel for maximum durability and reliability. Unlike even the best aluminum shifters, Skunk2 Racing steel shifters will not break. The added weight of the shifter results in smoother and more positive shifting. Each short shifter utilizes sealed bearings and a low friction coating to ensure smooth motion without binding.
Shift **** sold seperately.
The Dual Bend fits the 1994 - 2001 Integra
The Single Bend fits the 1990 - 1993 Integra, 1988 - 1991 Civiv & CRX, and the 1992 - 2000 Civic and Del Sol.
Click here for the Single Bend Short Shifter - $109.99
Click here for the Dual Bend Short Shifter - $109.99
Old Mar 12, 2009 | 09:58 AM
Default Re: Free shipping on ALL SKUNK2 Products!
Skunk2 Cams for the B18
These are the classic Skunk2 camshafts that they first introduced to the tuner market in 1999. Vehicles equipped with Skunk2 tuner camshafts have been dominating the streets and the tracks for almost a decade. To this day Skunk2's B-Series Stage 1 camshaft is the only CARB approved street legal performance camshaft in the world.
The Stage 2 camshaft has reached legendary status in the tuning world. And the Stage 3 camshaft has powered Skunk2 racing cars to numerous road racing and drag racing wins. Also for 2007, the Turbo 1 and Turbo 2 camshafts have been created to offer unparalleled performance for Street Turbocharged vehicles and feature Fast Ramp and Amax Technology.
All Skunk2's B Series cams are machined from high-strength chill cast billets using a Skunk2 proprietary iron alloy. The performance of Skunk2's B camshafts is further improved when used with a Skunk2 intake manifold, valvetrain, and cam gears.
Click Here to order the Skunk2 B18 Stage 1, 2, or 3 Cams - $599.99
Click here to order the Skunk2 Pro-Series Stage 1 Cams - $625.99
Skunk2 OBDII to OBD1 Conversion Harness
This harness offers an alternative for owners of 1996-2001 Honda/Acura vehicles hindered by the OBD2 ECU. Along with an OBD1 ECU, this harness will convert the vehicle to OBD1. No cutting or soldering is needed. For optimum results, use with Hondata/Skunk2 ECU’s.
Click Here to order your Skunk2 OBD2 to OBD1 Conversion Harness - $143.99
Skunk2 Billet Aluminum Plug Wire Cover
Skunk2 billet wire covers are CNC-machined to be extra lightweight. Each wire cover is fully polished and features a contrasting, acid-etched Skunk2 Racing logo. V-TEC ONLY
Click Here to order your Skunk2 Billet Aluminum Wire Cover
Skunk2 Cam Plug Seal
Fits All Honda B/H/D/F
The Skunk2 cam seal is precision CNC machined from aircraft quality 6061-T6 alluminum billet and is gun metal anodized for a durable finish. The Skunk2 cam seal features three o-rings for a superior fit and seal compared to the factory plastic seal which has no o-rings. Includes a laser-etched Skunk2 logo design to make the Skunk2 cam seal a perfect addition to your engine along with other Skunk2 accessories.
Click here to order your Skunk2 Cam Seal
Skunk2 Magnetic Drain Plugs
Skunk2 Magnetic Drain Plug Set includes both engine and transmission plugs to help extend engine life by removing harmful metal particles from your engine oiling system thus prolonging bearing and transmission gear life. Skunk2 Magnetic Drain Plugs are designed to racing specifications and feature lightened bolt heads that are cross-drilled for use with safety wire. Skunk2 Magnetic Drain Plugs are easy to install and can easily be cleaned after each oil change.
Fits all Honda, Acura, Mitsubishi, Ford, and GM MANUAL transmissions. May fit some automatic transmissions but it is the owners responsibility to determine if product will work for their specific application.
Click here to order your Skunk2 Magnetic Drain Plugs - $29.99
Skunk2 Mega Power "R" 70mm Exhaust for the 07+ Civic SI Sedan
Skunk2 is pleased to announce our all new line of 70mm Mega Power R exhaust systems for the 2007+ Honda Civic Si Sedan. Skunk2 Mega Power R exhaust systems are based off of the exhaust systems we custom build for our road race and time attack cars. These systems are designed for highly modified naturally aspirated or turbocharged applications that require more exhaust flow than what is achievable with the our standard 60mm Mega Power exhaust systems. Dyno-proven for maximum horsepower, Skunk2 Racing Mega Power R cat-back systems are constructed from T-304 stainless steel, are robotically TIG welded, and feature CNC mandrel bending which allows the tubing to maintain a constant diameter throughout. Each system is designed with oversized tubing and mufflers to achieve the additional flow that is required for high horsepower vehicles. A Skunk2 removable silencer and all necessary hardware are also included.
- Ideal for Highly Modified NA and Turbocharged Vehicles
- Optimized Free-Flow Design
- Super Low Restriction Oversized Muffler
- Robotically TIG Welded
- T-304 Stainless Steel
- Precision CNC Mandrel Bent
- Includes Removable Silencer
Click here to order your Skunk2 Civic SI Sedan Mega Power "R" Exhaust - $525.99
Old Mar 13, 2009 | 07:35 AM
TGIF bump.
Old Mar 16, 2009 | 06:54 AM
TGIM bump.
Old Mar 16, 2009 | 12:20 PM
Back to the top.
Old Mar 17, 2009 | 06:44 AM
Tuesday morning bump.
Old Mar 18, 2009 | 07:52 AM
Wednesday morning bump.
Old Mar 19, 2009 | 12:06 PM
Thursday bump.
Old Mar 24, 2009 | 09:38 AM
Tuesday bump.
Old Mar 25, 2009 | 06:25 AM
Mid-week bump.
Old Mar 26, 2009 | 07:17 AM
Thursday bump.
Old Mar 27, 2009 | 07:51 AM
TGIF Snow Bump.
Old Mar 30, 2009 | 06:37 AM
TGIM bump.
Old Apr 1, 2009 | 06:50 AM
April Fools bump.
Old Apr 2, 2009 | 07:32 AM
Thursday bump.
Old Apr 3, 2009 | 09:59 AM
TGIF bump.
Old Apr 7, 2009 | 10:24 AM
Tuesday bump.
Old Apr 9, 2009 | 07:28 AM
Thursday bump.
Old Apr 10, 2009 | 12:07 PM
sparky2pipes's Avatar
do you ship to the uk??
if you do can i have a price for the Skunk2 Composite Fuel Rail shipped to ca289af England.
Old Apr 10, 2009 | 12:30 PM
PM sent.
Old Apr 13, 2009 | 10:52 AM
TGIM bump.
Old Apr 17, 2009 | 09:11 AM
Friday Snow Bump.
Old Apr 17, 2009 | 11:04 AM
seadonkeyraypiss's Avatar
Where's the composite intake manifold?
Old Apr 22, 2009 | 06:12 AM
That is a great question. We have been waiting for them for a while too. I asked the guys at Skunk2, and they are still telling me that they don't have an ETA for them yet. Stay tuned. As soon as they come out, we'll get them up.
J. Cooley
Old Apr 22, 2009 | 06:29 AM
HONDRETTI's Avatar
great looking products
where's the infamous mega-power header?
