Front Tag Relocation??
i cut out my front bumper (the white thing is reinforcement so it doesnt flap everywhere on track days)
i picked up this front tag mount from a friend off his EF sedan
i want to mount it on the drivers side but the only thing I can seem to think of is drill a hole in the front reinforcement behind the bumper and run a long bolt and a bunch of washers, i was wondering if any of you guys could come up with any better ideas...
Search for "license plate relocator" on ebay. There should be tons of them. You're still going to have to drill the front bumper, but at least it's on a part that cannot be normally seen. So if you decide to change your mind, you can go back to your normal plate location.
Is that bracket long enough to reach the radiator support? If not, looks like basic steel stock. You could probably pick up a length at a harware store and bend it to fit properly.
I ditched the plate "frame" and attached my plate straight to the bracket.
CALC!_JUST_du_IT!
Aug 26, 2008 10:36 AM
