FOG LiGHTS DON'T WORK.
I've got a 94 gsr I bought with jdm front. Fog lights don't work. If it is the fuse, does anyone know which fuse it would be? The headlights still work (hid) so I know it isn't that. Before I try replacing bulbs, let me know. thanks.
Are you sure the previous owner actually wired up the fogs? If they did the fuse will more than likely not be found in the fuse box, it may be under the dash but it will probably be an inline fuse. Check out my write up and double check to make sure it is wired properly.
https://honda-tech.com/forums/lighting-107/how-jdm-itr-hid-headlight-fog-light-wiring-2195061/
vdubsduncutit
10
May 11, 2010 02:16 PM
