Cooling Fan
Old Mar 11, 2009 | 10:27 PM
hondaboi7's Avatar
Default Cooling Fan
Are cooling fan suppose to be on in the winter or no because my is not on? I know this may sound dumb but its bugging me.
Old Mar 12, 2009 | 04:12 AM
civicgsr's Avatar
Default Re: Cooling Fan
The fans are simply controlled by engine temp. Cold outside temp will keep the engine temp down reducing the use of the engine fan.
Old Mar 12, 2009 | 05:53 AM
superbean's Avatar
It just depends on how cold. Even though the rad temps will be down, your thermostat should still work properly to get the motor up to temp
Old Mar 12, 2009 | 07:49 AM
honda.lioness's Avatar
I recently changed the thermostat on my 93 Civic DX and so had to do an air purge of the cooling system afterwards. From cold idle to full warmup (= cooling fan comes on twice) required 40 minutes at an ambient temperature of 55 degrees F. I have timed this many times with my two Civics, and 20-50 minutes is always necessary (20 minutes being in the heat of summer). I do not think my fan otherwise comes on in winter temps when I am driving. The cool winter-y air flowing over the radiator keeps the system plenty cool.
If you are very concerned, there are ways to test the fan and fan relay.
torino420
May 5, 2013 08:07 AM
dth0ng69
Jan 28, 2009 06:19 AM
EFOwNzALL
Jun 24, 2008 09:09 AM
eric_ches
Dec 29, 2007 01:49 PM
CivicFerio
Jul 22, 2001 07:07 PM
