Do i really need this??? Please help!!!!
Old Mar 11, 2009 | 07:38 PM
aceboog3x's Avatar
Icon3 Do i really need this??? Please help!!!!
okay so i recently did a gsr swap on my 97 ek hatchback and now i ordered my exhaust (buddy club pro) and i have a high flow cat already. this is the last of the things that i need as of right now for my swap but i was wondering did i need anything else before i get my exhaust put on?
now i heard that my exhasut will not bolt directly on because the flanges from my exhaust is different from the flanges on the down pipe of the motor. a friend of mine told me that i would have 2 either get the hi-flow cat cut and welded so that the flanges match, or get a header for a b16 so that it will bolt directly up with no cutting. so my question is, DO I REALLY NEED TO GET THE HEADER FOR THE B16 OR DO I REALLY HAVE 2 CUT AND WELD????? PLEASE HELP!!! THANKS
Old Mar 11, 2009 | 08:17 PM
b17 turbo's Avatar
Default Re: Do i really need this??? Please help!!!!
if im not mistaken i think your gonna have to cut and weld. when i did my b16 swap the flang hole on the downpipe and header didnt line up luckily i had a gsr cat i swap on
Old Mar 11, 2009 | 08:25 PM
aceboog3x's Avatar
so then basically i would need to get a gsr cat and i would be good
Old Mar 12, 2009 | 10:05 PM
aceboog3x's Avatar
so nobody know's anything??? i know somebody had 2 come across this issue if its even an issue. let me know something
Old Mar 13, 2009 | 03:34 AM
RxglassJAw's Avatar
Just get it cut and welded, instead of trying to figure out what part will swap in there perfectly. It should be cheaper than a new cat and it will fit better. When did my ls swap i got the correct cat but it ended up being a tiny bit off and touched the body in places and made a horrible rattling... when to the exhaust shop and 20 mins later it was perfect.
Old Mar 13, 2009 | 04:25 AM
superbean's Avatar
Yep. The exhaust shop can look at it and has the right tools to make it work much easier. It would take them no time to fab up a custom s pipe to make the two connect real well.
I would say 50 bucks max to finish up the exhaust with labor.
Old Mar 13, 2009 | 05:42 AM
cjtimp's Avatar
Yup.......weld or fab it........
Old Mar 13, 2009 | 06:12 AM
fastrxu's Avatar
weld it
Old Mar 13, 2009 | 07:55 AM
aceboog3x's Avatar
iight thanx alot, all of u. jus wanted 2 know and make sure what was what. good lookin
Old Mar 13, 2009 | 08:20 AM
kenn051886's Avatar
dont listen the these idiots. welding just makes it alot harder when u want to change something later or possibly make repairs and it looks tacky. header should bolt up perfectly with the cat. when i did my swap i had a stock cat and stock exhaust and the header lined up exactly where it should have.
Old Mar 13, 2009 | 08:28 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Depends on the car, and no one here is talking about welding the entire exhaust together. Just because you've never seen the problem yourself doesn't mean it doesn't exist. I can guarantee that this problem exists for some cars, because it did on mine. A GSR header DOES NOT always line up perfectly with a Civic cat.
I'm not sure what year/trim civics, but some (mine included - 2000 EX coupe) the header flange does not mate up to the cat flange. At all. Not no way, not no how. Period. The bolt holes on the flanges are 90 degrees opposite each other, and the stock exhaust is *just barely* too short to mate up to the GSR header... you can get them together, but you won't really get a good seal on the doughnut.
I took mine to an exhaust shop and had him cut the flange off the front of the cat. He added about 1.5" of length to the front of the cat, then welded the flange back on so that the bolt holes lined up with the bolt holes on the GSR header. To do this, he basically rotated the flange about 90 degrees. That's it. Perfect. It's all still bolted together, and will come apart easily when I need to work with it. No one here is talking about Bubba'ing an exhaust together.
Old Mar 18, 2009 | 12:53 AM
fastrxu's Avatar
my dx had the cat on the stock header so dc headers bolt up to exhaust but there's no cat. How else do you suppose you fit a cat in there without cutting/welding
g2tegsownsgirl
Apr 23, 2006 01:26 PM
NsX_CrX
Oct 23, 2005 10:09 PM
vtecdc2
Mar 3, 2003 04:20 PM
WangChung
Feb 21, 2003 06:58 PM
E-AT_me
Jan 31, 2002 10:54 AM
