ohh my goodness. beware of pulstar pulse plugs
just like the title said. i know i said that they are great and all that before, but i take all that back. they are fine for the first 10k miles lol
holy crap i was shi*ting bricks when this happened!
well i was on my way home from a job interview today and i was on the freeway doing 111 km/h with cruise control. there was a semi truck in front of me, so i moved over and hit the button to speed up, well when i started to speed up my car hesitated very bad and the next thing i know i saw smoke coming out from under my hood. my first thought was "no way i blew my motor on cruise control.... how embarrassing..." so i pulled over and popped my hood and checked it out and i noticed smoke coming up from under my spark plug cover. i didnt have tools so i said screw it ill see if i can make it home. so i started it up and it sounded perfectly normal and idled fine, but when i would go more than half throttle, it would misfire real bad and it was weird cuz i didnt have a cel. but anyways i made it home, and took off the million pieces to get to my spark plugs. well the first thing i saw when i took off the caps was a brownish-red tint on all 4 of the spark plug holes. from this point on i just thought that they fouled real bad. when i got them out, i noticed the brown-ish red tint on all 4 plugs around where the plastic meets the metal thread. but i put my OEM Denso plugs back in it still misfired for a little bit, but i just disconnected my battery and reconnected it and its perfect again! im gonna call pulstar tomorrow about this.
so yea. watch out for them pulstars.
how long would you wait till you change out your plugs???
please update im very interested in these plugs but now i keep hearing problems left and right, oh and you had denso plugs stock or just had denso plugs around, cause i swear my stocks were ngks but that was a long time ago that i cant remember what was stock ... lol
you should be here then.
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/
hahaha jk jk dude.
i was really satisfied with the pulstars at first and i thought they were gonna last the 50k miles its claimed to last, but apparently not.
oh man u dont even know how bad i was shitting bricks cuz i thought my motor went out on me.
hahaha jk jk dude.
My '98 Civic EX actually has both listed in the parts catalog. The '08 Civic Si has the Densos listed. The '06 RSX Type-S lists both also.
although true, especially with platinum, you should still always check to make sure they arent fouled, sometimes with cars arent maintained properly and that could lead to a shorter lifespan, or if you run higher octane when your not tuned for it, or whatever else since most of us here are modifying our cars for track or drag use can also shorten the lifespan of your plugs, i doesnt hurt to change them out even before their expected lifespan if you find them fouled, misfiring, etc., or even simply for performance and emissions upgrading ... in this case i would figure the reason for changing them to pulsestar was performance ... do you wait for 100k before checking your spark plugs???
do you think NGKs or Densos are better for racing performance?
i feel you on that, i read a lot the articles on them and looked at the dyno graphs, but on some forums i find people saying that they are over rated, and now your thread may even prove they arent worth trying out at all now ...
ngk's and denso's are very similar in design so i cant really say which is better. on my dirtbike, i wont put anything but ngk cuz thats what it came with. and im gonna do the same on this car. it came with denso so im gonna stick with denso. and besides, the whole ignition is pretty much denso so why not run denso plugs? makes sense?
http://www.acuraoemparts.com/delray/...All&vinsrch=no
although true, especially with platinum, you should still always check to make sure they arent fouled, sometimes with cars arent maintained properly and that could lead to a shorter lifespan, or if you run higher octane when your not tuned for it, or whatever else since most of us here are modifying our cars for track or drag use can also shorten the lifespan of your plugs, i doesnt hurt to change them out even before their expected lifespan if you find them fouled, misfiring, etc., or even simply for performance and emissions upgrading ... In this case i would figure the reason for changing them to pulsestar was performance ... Do you wait for 100k before checking your spark plugs???
also, putting a few periods in that jumble of words would make it a lot easier to understand what you're trying to say. just sayin'.
did you know that people with built turbo motors still run ngk spark plugs? they just change the temp range and gapping. there is NO reason to ever change the brand of spark plugs. if your motor is stock or near stock, there's NO reason to ever change the plugs from what originally came in the car. don't give to the hype about some super awesome spark plugs; oem is best.
Honda's stock ignition systems are very good. Unless you're doing something drastic to the motor, there's really no reason to change any of it. It's just asking for trouble.
Edit: Personal example: on my old Prelude VTEC, I went in to do maintenance on the cap/rotor of my distributor, using Autozone parts. Afterwords, my radar detector's laser function kept going crazy when I'd rev past 4k RPM. Bought an OEM dist. cap, and everything went back to normal. Just that one non-OEM part was causing all kinds of extra EMF.
