Help my fuel cuts out!
Old Mar 11, 2009 | 04:26 PM
LSXFEIND's Avatar
Default Help my fuel cuts out!
i swapped a mini me with a y8 head on it i have everything hooked up its running on a OBD2 Converted Distributor with the OBD0 SI Harness with OBD1 injectors with a P28 ECU BUT it idles fine just a lil high when i rev it it will go but then ill try to rev it a lil higher it cuts out it sounds like it has 2 Step or sometin lol but i just wanna get this lil project going!!! any suggestions?!!! by the way i already tried a OBD0 Distributor and it does the same thing!!
Old Mar 11, 2009 | 04:32 PM
jdm602's Avatar
Default Re: Help my fuel cuts out!
check what code your throwing. ecu is chillin in limp mode.
Old Mar 11, 2009 | 04:33 PM
LSXFEIND's Avatar
ok kool but how can you tell what code it is?
Old Mar 12, 2009 | 10:17 PM
jdm602's Avatar
find the little 2wire blue plug by the ecu and loop a paperclip between the 2 wires and check engine should blink a certain amount of times and certain duration.
Old Mar 13, 2009 | 04:37 AM
jhammond_82's Avatar
Reject Papi
^what he said.
Old Mar 13, 2009 | 07:37 AM
LSXFEIND's Avatar
ok it gave me wierd codes though like 4, 6 ,24??????
HatchWarehouse
Apr 18, 2006 03:00 PM
mike34655
Jan 2, 2005 01:47 AM
TS4L
Mar 12, 2004 10:33 AM
GuyInASpeedo
14
Sep 24, 2003 07:34 AM
91civicEX
15
Sep 3, 2003 10:33 PM
