Effects of Performance Radiator Caps?
Old Mar 11, 2009 | 03:41 PM
puertoricanboy90's Avatar
Default Effects of Performance Radiator Caps?
I want to know how much more effective racing radiator caps are over oem. The difference would be 1.3kg/cm^2 compared to the oem's 1.1kg/cm^2. I know the boiling point would rise and the freezing point would become even lower. But would this translate into a cooler running engine? Would there be a noticeable performance difference? Any help would be appreciated.
Old Mar 11, 2009 | 03:43 PM
CRX Toad's Avatar
Default Re: Effects of Performance Radiator Caps?
It isn't going to do anything for performance and your thermostat still opens at the same temp. It is really your choice but I don't see the need.
Old Mar 11, 2009 | 06:28 PM
Crx Jimmy's Avatar
the only benefit would be if your system was at its max cooling capacity, it would just be longer before the water boils. it would not "cool" better
Old Mar 11, 2009 | 07:45 PM
24TEN's Avatar
PHANTOM MENACE
Personally, I have a spoon radiator cap on a stock radiator. Runs the same as before BUT the needle gradually goes back to the lowest notch on the temp gauge under full throttle. Don't know how the cap makes it do that. I bought one for my EG and it doesn't do that. Go figure.
Old Mar 11, 2009 | 08:09 PM
egyolk's Avatar
i've always wondered what these things would do
Old Mar 12, 2009 | 05:57 AM
MonkeyMagic's Avatar
it keeps the water from boiling when it is exchanging more heat from racing. (the higher the pressure the more energy it is absorbing before it boils) don't know if i worded that quite rite
but i've had the stock radiator cap on everything... but then again i've never done 25 hot laps in a row at tsukuba.
1 2 NV
Jan 31, 2007 08:38 PM
Captn Shakelford.
Sep 7, 2005 10:08 PM
95blk2draccordEXMT
Jul 23, 2003 10:00 AM
96Integ
Jul 17, 2002 01:57 PM
94GSRRacer2
May 8, 2002 08:04 PM
