What cams should used on b18c ?
Old Mar 11, 2009 | 01:10 PM
juan3023's Avatar
Default What cams should used on b18c ?
ok here is my question I have a b18cblock bore 84.50, je pistons 11:1 compression ,eagle H beam connecting rods,3 angel job,tatium reatiners,dual valve springs,ARP studs,total seal rings,acl rods & main berings,eagle 27lbs knifed edge, ect which cams do you guys recomend to buy for my set up ?
Old Mar 11, 2009 | 01:58 PM
JerseySiPOS's Avatar
Default Re: What cams should used on b18c ?
Type-R
Old Mar 11, 2009 | 02:30 PM
KuEy's Avatar
since you replaced teh valvetrain with aftermarket stuff, i say get crower cams or skunk2 HSL cams.
Old Mar 11, 2009 | 05:34 PM
killerpenguin21's Avatar
weird ive never heard of skunk2 hsl's
Old Mar 11, 2009 | 09:35 PM
juan3023's Avatar
Originally Posted by JerseySiPOS
Type-R
Those are the ones I have right know but i was thinking of going
aftermarket cams .
Old Mar 11, 2009 | 10:31 PM
juan3023's Avatar
yeah thats what I was thinking crower cam by the way what do you mean by HSL?
Old Mar 11, 2009 | 10:36 PM
juan3023's Avatar
Any one have more suggestions
Old Mar 11, 2009 | 10:51 PM
racebum's Avatar
crowers cam breaking issues scare me. had a set break once. not again. you're in a weird place compression wise. buddy club 3s come to mine. skunk 1s maybe but either is barely larger than the ITR. lot of cash for a couple hp. i have no clue how the skunk pro 1s would behave at that compression but if you're going to upgrade, that's a lot more of a step up in size. if the car is tuned on R cams already i would stay there. i just see $1000 being spent in cams and tuning for 5-8whp
Old Mar 11, 2009 | 11:45 PM
juan3023's Avatar
Thank you very much
well I am builing my motor so I can hit the dyno
Old Mar 12, 2009 | 04:22 AM
bigG's Avatar
what is your power goal or goal in general with the motor
Old Mar 12, 2009 | 07:01 AM
aftermarket cams .
they are the best with the right combination. save your money and time, don't get aftermarket parts. Expect a stretch slow curve and a big percentage torque loss with any other aftermarket cam or bolt ons.
Old Mar 12, 2009 | 08:35 PM
UncleD's Avatar
Funny to me that nobody has asked about the cylinder head. You have displacement. WHY NOT do a Pro2 or M24xx?? I have a customer with smaller displacement than you with .5ish more compression than you and makes 250+ whp blowing through a CAT on pump gas using M24xx's. Why does everybody only look at compression #'s when it comes to camshafts??
Old Mar 12, 2009 | 09:13 PM
juan3023's Avatar
here is my goal to get it tune & to make around 200 hp
Old Mar 12, 2009 | 09:33 PM
juan3023's Avatar
Thank you very much so you recomend me to go with the pro2 or m24 right .
Old Mar 13, 2009 | 01:09 PM
KuEy's Avatar
oppsss. i meant to say the skunk2 pro1 or blox hsl.
Old Mar 13, 2009 | 01:26 PM
racebum's Avatar
keep us posted on the power difference between the R cams and pro 1s if you go that way. since you have the displacement you may get some strong results. i have no clue, am curious though.
kennie555
Feb 22, 2013 12:45 PM
WheaMyRyceGo
14
Sep 14, 2009 10:11 PM
IamVtec
Jul 6, 2009 06:01 PM
BLK99VTECR
Jun 14, 2004 09:58 PM
toolowsol
Mar 14, 2004 04:17 AM
