Acura Integra LS
Old Mar 11, 2009 | 09:27 AM
Sharwood2008's Avatar
New User
Icon6 Acura Integra LS
My Radiator fans have not been turning on which is causing my engine to over heat dump coolant into the overflow and when the overflow gets full it has alittle leak under the care around the area of the overflow.
1. i have changed the radiator
2 rad hoses
3 thermostat and sensor
4 i also have checked all the relays everything works fine in the ecu when i take the relay out and put a wire on the 2 ends the fans work. when i put direct power the the wires the come off of the sensor they work.
when i drive my fans do not kick in when the car gets to operating temperature. my car then starts to overheat i have done everything that i have read on forums and nothing has worked yet.
any help
Old Mar 11, 2009 | 10:10 AM
mrdeadman's Avatar
They let me pick
Default Re: Acura Integra LS
any help
This should've led you in the direction of replacing the relay. If you bypass the relay and they work then it should have something to do with the relay.
Old Mar 11, 2009 | 10:43 AM
New User
the relay is fine i switched it out with another one and it still does not work
i also tested the relay by putting power on it and testing the other ends i get 12 volts
Old Mar 11, 2009 | 11:01 AM
mrdeadman's Avatar
They let me pick
Test all lines running to the relay: the one to switch it on and the one that runs to the fans.
Old Mar 11, 2009 | 11:31 AM
limit's Avatar
check the temperature switch....
Old Mar 11, 2009 | 11:40 AM
New User
If that's the one on the back of the thermostat housing I have already switched that one out
Old Mar 11, 2009 | 12:06 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
https://honda-tech.com/forums/acura-integra-6/creating-new-topic-choose-subject-specific-title-not-help-me-asap-2477272/
Old Mar 14, 2009 | 04:18 PM
luisrblue's Avatar
where's the thermo on a 95 teg ls b18 [noob]
Old Mar 14, 2009 | 05:23 PM
pico4130's Avatar
New User
One possibility is a slight leak in the head gasket.It can pump compression into the coolant and overflow the radiator into the recovery tank.I have had a few Civics do it.Dont mean to scare you but it can happen even with no visable coolant in your oil.
Allisonjohn32
Feb 2, 2019 06:03 PM
swzen
Honda Civic (2006 - 2015)
May 12, 2014 04:54 PM
4CDFED
11
Aug 9, 2006 06:03 PM
Integra Integra
Dec 3, 2005 09:25 PM
jigsaw
May 3, 2003 09:20 AM
