Tire pressure? Kumho asx 205/45/16
Old Mar 11, 2009 | 09:18 AM
vietxdragon's Avatar
Default Tire pressure? Kumho asx 205/45/16
Hey guys i just bought some kumho asx's 205/45/16 for my 95 integra gsr sedan and i was wondering what tire pressure should i run these at? I usually run my tires at 35 on all sides. Do ASX's have a "G" spot ? Or should i just run them at 35? I figured for 200 shipped not bad
Old Mar 11, 2009 | 10:34 AM
Smarg's Avatar
Default Re: Tire pressure? Kumho asx 205/45/16
I usually run mine at 30psi. all the way around.
Old Mar 11, 2009 | 11:22 AM
TunerN00b's Avatar
You should run whatever pressure it says on your door jamb, and adjust only if you see wear which would indicate it is the wrong pressure.
Old Mar 11, 2009 | 03:14 PM
nsxtasy's Avatar
H-T Order of Merit
Yup. The recommended pressures on a GS-R - what you'll find on the door jamb and in the owner's manual - are 35 psi front, 33 psi rear. Try that. If you find that you'd like to change it, based on tire wear or handling etc, then change it however you want, in 2 psi increments.
I've found on my GS-R that 35F/33R works very well with all the street tires I've used (summer tires, winter tires, etc).
Old Mar 12, 2009 | 05:40 PM
thank you for all your comments! Also, is there a way to fix toe yourself ?? no one around here can fit my car on their alignment racks
Old Mar 13, 2009 | 12:14 AM
bmoua's Avatar
I'm currently running 35F/35R on my 99 civic coupe, i like my tires a bit stiffer.
Old Mar 13, 2009 | 11:58 AM
TunerN00b's Avatar
There are ways to do your own alignment. Get ready to use a ton of string...
But its easiest to just take the bumper cover off and put it on a rack.
Jaydeep
13
Jul 25, 2010 09:27 PM
integ3x21
Jun 25, 2008 04:03 PM
adrian1281
Jun 28, 2003 08:39 AM
FullMetalJacket
12
Feb 28, 2003 07:32 PM
BlueG3Teg
Mar 24, 2002 06:46 AM
