Fuel Cuts OuT??? why???
Old Mar 11, 2009 | 07:20 AM
LSXFEIND's Avatar
Default Fuel Cuts OuT??? why???
i have a EF i just swapped a mini me in it it runs and idles fine but i try to give it gas and the fuel cuts out? i have the OBD0 SI harnes with the OBD0 Distributor but with a P28 ECU with OBD1 Injectors??? is that not a good mix???
Old Mar 11, 2009 | 07:28 AM
jlicrx's Avatar
Default Re: Fuel Cuts OuT??? why???
you can't use the OBD0 distributor with the OBD1 ECU - with OBD1 injectors, you don't use a resistor box
Old Mar 11, 2009 | 07:31 AM
LSXFEIND's Avatar
ok? how should i set it up then?
Serdar
Apr 18, 2019 03:15 PM
delsol92
Nov 21, 2011 10:30 PM
brock316
Jan 11, 2011 09:07 PM
lance_ecl
Apr 8, 2007 11:03 AM
BLUE EH3
Feb 16, 2007 06:28 AM
