Car reving by itself after nitrous spray! HELP!
Old Mar 10, 2009 | 09:04 PM
NosShootinHonda's Avatar
Default Car reving by itself after nitrous spray! HELP!
My friend sprayed nitrous in his GSR Integra, but then the vaccum hose came off the fuel pressure regulator and the car started to have a jumping idle. We put the hose back on and now it stopped jumping, but it's reving at 3000 rpm. Sometimes, it still does the jumping idle 1000 to 3000 rpm. Any clues to what this problem could be? He already tried cleaning the idle air control valve and the problem still persists. Thanks! The GSR still runs strong and the VTEC still pulls hard. We just can't figure out why it idles high and jumps sometimes.
Old Mar 10, 2009 | 11:10 PM
my_hidden_romance's Avatar
Default Re: Car reving by itself after nitrous spray! HELP!
did you jump a rib on the timing belt? threw off the timing?
Old Mar 11, 2009 | 05:27 AM
That's what we thought, but the timing is on perfect at TDC. Just can't figure out what is going on.
Old Mar 11, 2009 | 11:38 AM
Changed out the IACV and still problem continues. Tested my old IACV on my friend's GSR and it idles fine. Any clues? Thanks!
Old Mar 11, 2009 | 11:41 AM
a2dadamm's Avatar
i was gonna say to change it out but i see u tried already.. ummmmmmmm idk lol good luck
Old Mar 11, 2009 | 02:11 PM
DrGrEeNtHuMb's Avatar
Take and light a ciggarette. Run it around the intake manifold and everything intake on your engine. Hopefully the smoke will get sucked into the motor and you"ll find your vacuum leak. You probably popped the intake manifold gasket out. Thats what i did to mine
Old Mar 11, 2009 | 04:08 PM
JRSC01GS-R's Avatar
better hope u have no fuel leaks
Old Mar 12, 2009 | 07:29 AM
trustdestruction's Avatar
yea... don't do that. lol
use carb/TB cleaner to locate a vacuum leak. do that by spraying parts of your vacuum lines while the engine is running and seeing if the idle changes.
OP: It could be the FITV. When the engine is warmed up, put your finger over the ports in the throttle body that go to the FITV. You should not have vacuum in any of those ports.
(I'm in the Integra section because of a search and figured I would try to help since I saw this. lol)
Old Mar 12, 2009 | 07:31 AM
He'll be fine. They proved on mythbusters that a cig can't xatxh it on fire like in the movies, it just gets put out. But if you don't wanna use a cig, get a spray bottle full of water and spray it along ur manifold. If you have a good leak the water will suck up and ur motor will bog. Also try to cover the top hole inside ur throttle body with ur finger and see if that takes the idle back to normal. If it does cover it up with some electrical tape
Old Mar 12, 2009 | 07:35 AM
LOL
You do know that you aren't suppose to suck water into the engine, right?
Or he could actually fix the problem instead of rigging it and risking possibly sucking electrical tape into his engine...
Old Mar 12, 2009 | 10:54 AM
Originally Posted by trustdestruction
LOL
First off [edited - don't resort to name calling] the water won't do anyrthing to the motor. He is just searching for a vacuum leak, its not like he is running it in his fuel tank. And I'm just offering ways to fix his problem. Granted its not the right way (electrical tape) but it will work. If he has fixed his iacv and fitv, and there is no leak on the IM then that hole is the only thing I've EVER found to fix the problem.
I've had this same problem on my gsr. Clean fitv, NEW iacv, NEW sensors and TB, replaced BOTH Intake mani and TB gasket. I basically replaced the whole intake side of my head and the electrical tape made it pur purrfect.
To the OP, just try the smoke idea, if u don't find it try covering the hole with a finger. If it fixes it, find the right way to fix it or plug the hole. I'm sure its what it is and I even learned to plug that hole from Honda-tech.com
Last edited by PatrickGSR94; Mar 12, 2009 at 07:31 PM. Reason: removing name calling
Old Mar 12, 2009 | 11:31 AM
418whpturboD's Avatar
does it do it when you disarm the nitrous? i had a problem just like this wwhen i had nitrous.. the nitrous button was messed up and was spraying nitrous all the time.. disarmed it and it would stop.. i had to get a new micro switch..
Old Mar 12, 2009 | 11:43 AM
Yeah, i took out the nitrous and no more spraying for me! Well, I found that my #1 cylinder was flooded with oil when taking out the spark plug. I stuffed napkins in there to remove it and now it doesn't rev up, but it revs high, like around 3500 and stays there. Any more opinions? Thanks you all the above posts!
Old Mar 12, 2009 | 12:33 PM
Mr. Self Destruct's Avatar
Opinions???? Uhhhh, haha, how about, figure out why the cylinder was filled with oil? Lol.
*Cringes at the thought of another "nawz blowed up my moter" thread...*
Old Mar 12, 2009 | 03:01 PM
First off the water won't do anyrthing to the motor. He is just searching for a vacuum leak, its not like he is running it in his fuel tank. And I'm just offering ways to fix his problem. Granted its not the right way (electrical tape) but it will work. If he has fixed his iacv and fitv, and there is no leak on the IM then that hole is the only thing I've EVER found to fix the problem.
Don't resort to calling names. Only makes you look childish. I have no intention of calling you names, so why you gotta try to turn this into a pissing contest?
I'm not saying spraying water on the intake manifold will give him problems.
However, you said "If you have a good leak the water will suck up and ur motor will bog.." If it actually "suck[ed] up" like you said it would, he would have some serious problems.
Last edited by PatrickGSR94; Mar 12, 2009 at 07:31 PM. Reason: cleaning up quoted post
Old Mar 12, 2009 | 03:05 PM
MidShipCivic's Avatar
Leaking nitrous solenoids will cause a motor to rev up. Close the valve on the bottle and see if this abnormality continues.
Old Mar 12, 2009 | 03:36 PM
delbert's Avatar
fawk nitrious
Old Mar 12, 2009 | 07:30 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If only a small amount of water is sucked into the engine, it will just turn to steam and get blown out the exhaust. Only when the volume of water exceeds the combustion chamber volume do you start bending rods and valves, etc.
Old Mar 12, 2009 | 07:36 PM
Thank you for the clarification/explanation.
Old Mar 13, 2009 | 09:32 AM
My bad
Hope you get it fixed OP
Old Mar 13, 2009 | 10:21 AM
connor53's Avatar
Map sensor and TPS? Unplug both and see if problem changes at all. One at a time.
Vachy
Oct 10, 2013 01:35 PM
ch4nq
Nov 21, 2006 05:09 PM
stoopid_monkey
Apr 26, 2005 11:22 PM
1hotcivicSi
Mar 16, 2004 02:01 PM
REDBARON
Oct 4, 2001 07:40 PM
