Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Golden Eagle VTEC Conversion Kit- Fuel Rail- Block Guard- Vacuum Manifold- Tow Hook
Old Mar 10, 2009 | 06:37 PM
robear78's Avatar
Default Golden Eagle VTEC Conversion Kit- Fuel Rail- Block Guard- Vacuum Manifold- Tow Hook
http://www.robearracing.com
We stock ALOT of Golden Eagle, and also have access to ANYTHING they manufacturer!
Vacuum Manifold
Polish, Red, Blue, Black, Red
$40 each
Brass Barb Fittings
$15 each kit or $10 with purchase of a Vacuum Manifold
Golden Eagle Block Guard - This is the GUARANTEED the best Block guard on the market!! Dont cheap out on this insurance for your motor.
B16/B18 - $100
B20 - $110
K20 - $110
D16 - $100
Golden Eagle VTEC Oil Conversion Kit - LS/VTEC or B20/VTEC
WE WILL NOT BE UNDERSOLD!!
IF YOU FIND A BETTER PRICE, WE WILL BEAT IT!!
We sell this kit with and without a headgasket!! So please inquire before buying ANYWHERE else.
- We now have a Full Vtec Conversion System for people that want to use an LS/VTEC or B20/VTEC set-up.
- This kit is the easiest and most complete way to supply oil to the head without any machining required and is very clean and reliable.
The kit includes:
- 1. Golden Eagle Vtec Conversion Sandwich Plate with a -6AN fitting for the plate and head.
- 2. -6AN steel braided teflon hose for oil supply
- 3. Golden Eagle Vtec Conversion Dowels for proper alignment of the head and block without machining
- 4. 1/8 NPT tap and plug for the oil port in the head
- 5. Golden Eagle worked factory head gasket with any bore size and dowel holes opened for any application
-When we say " NO Machining " we mean that there is no reason that anyone cannot do this kit in their own garage. - The only thing that must be done is tapping the head for the plug .
- The VTEC line and fitting all use existing ports with no need to do anything else.
- Sold as a kit with full instructions.
Golden Eagle Head Stud & Main Stud Kit
B18C1 (GSR) - $120 Headstud Kit
K20/K24 - $120 Headstud Kit
B18C1 (GSR) - $60 Main Stud Kit
B16/B18/B20 - $60 Main Stud Kit
Golden Eagle Turbo Intake Manifold
-Designed using the latest CAD/CAM software for incomparable performance
-Precision CNC machined from 6061T6 billet aluminum
-The ORIGINAL billet manifold that has years of proven performance
-Precision tapered runners for optimal flow and H.P. gain over the stock manifold
-Accepts all factory sensors
-Options include:
-Extra injector bungs for alcohol running engines
-Custom throttle body plates for Mustang style throttle bodies
B16/B17 - Start at $660
B18A/B - Start at $660
B18C - Start at $660
D16 - Start at $660
H22/H23 - Start at $660
Golden Eagle Triple Ring Cam Seal
Blue, Red, Silver, Black
$22
Golden Eagle Front & Rear Tow Hooks (we do sell them seperately)
- 88-91 Civic/CRX
- 92-95 Civic
- 96-00 Civic
- 01-05 Civic
- 06-08 Civic (We have specific ones for you)
- 90-93 Integra
- 94-01 Integra
- 90-97 Accord
- 92-96 Prelude
- 97-01 Prelude
- 04-05 Fit (We have specific ones for you)
$120 for Front & Rear Tow Hook
$75 for Front Tow Hook
$52 for Rear Tow Hook
Golden Eagle Bumper Diffuser
Flat Black or Machine Finish
$110
Old Mar 10, 2009 | 06:58 PM
Krew3000's Avatar
Default Re: Golden Eagle VTEC Conversion Kit- Fuel Rail- Block Guard- Vacuum Manifold- Tow Ho
How much is the vtec oil line and adpater with and without head gasket
Old Mar 10, 2009 | 07:37 PM
robear78's Avatar
Answered a couple PM's. Hope to hear from you!
We are 100% Authorized and legit!! Ship daily!!
Old Mar 11, 2009 | 04:21 PM
robear78's Avatar
HT is great!!
Thanks for the recent orders!!
Old Mar 12, 2009 | 05:59 AM
JCB's Avatar
JCB
How much for a vtec conversion kit with the head gasket, a vacuum manifold, and the brass barb fittings shipped to 23072 pm me.
Thanks
Old Mar 12, 2009 | 03:52 PM
robear78's Avatar
PM's sent!!
Old Mar 13, 2009 | 11:19 AM
robear78's Avatar
bump for friday!!
I guarantee the best service and pricing on Golden Eagle!! We go there daily!!
Old Mar 13, 2009 | 11:42 AM
joe0522's Avatar
how much for the vtec oil line and sandwich plate kit with out head gasket shipped to 32034?
Old Mar 17, 2009 | 08:30 AM
robear78's Avatar
pm's sent!!
Thanks for the orders guys!!
Old Mar 20, 2009 | 05:01 PM
robear78's Avatar
ALOT in stock!!
Old Mar 23, 2009 | 04:18 PM
robear78's Avatar
Cam Gears should be ready in 1-2 weeks. Get your pre-orders in.
Old Mar 30, 2009 | 09:35 PM
robear78's Avatar
bump!!
Old Mar 31, 2009 | 12:46 PM
robear78's Avatar
bump!!
more VTEC kits in stock!!
Old Apr 1, 2009 | 12:15 PM
robear78's Avatar
bummpiityy!!
Old Apr 7, 2009 | 11:11 AM
robear78's Avatar
bump!!
Alot of K20 Fuel Rails in stock
Old Apr 9, 2009 | 01:03 PM
sparky2pipes's Avatar
i am interested in the golden eagal vacuum manifold, do you ship to the uk??
Old Apr 9, 2009 | 02:22 PM
JDMEGKOUPE's Avatar
bump
Old Apr 10, 2009 | 08:57 AM
robear78's Avatar
sure do.
Old Apr 10, 2009 | 11:41 AM
perfect, can i have price for the manifold and the fitting kit shipped to Ca289af England
Old Apr 14, 2009 | 06:22 PM
robear78's Avatar
bump!!
Old Apr 15, 2009 | 10:01 AM
did you get a price sorted out bud?
Old Apr 16, 2009 | 06:59 AM
bks84's Avatar
Loved
Looking for dowel pins and replacement o-ring for the sandwich adapter... shipped to 64055.
Old May 3, 2009 | 08:57 PM
egturbolsvtec's Avatar
how much for a lsv conversionkit with 83mm headgasket, polished b series fuel rail shipped to pa
Old May 5, 2009 | 09:44 AM
jmteggy's Avatar
New User
a much for the 81mm lsv kit and rod bolts shipped to 92843. Socal
Old May 13, 2009 | 10:54 AM
robear78's Avatar
ALOT in stock!!
Order online at http://www.robearracing.com
