JDM h22a bucking and loss power (non-vtec related)
Old Mar 10, 2009 | 04:34 PM
GraphiteMW's Avatar
Default JDM h22a bucking and loss power (non-vtec related)
When driving the car cold it has no problem with acceleration and keeping a steady RPM, but once it warms up the car will not hold a steady rate of speed (pedal held steady, instead the motor loses power) and acceleration is sluggish and bucky. The only way it will accelerate "decent" is when I slam the throttle.
I pulled the O2 sensor and notice it has white deposits all around the shield. I do remember that I had a bad power steering leak which caused it to drip onto the exhaust down pipe where the O2 sensor is located. Any suggestions?
Old Mar 10, 2009 | 05:17 PM
MLBZ521's Avatar
Default Re: JDM h22a bucking and loss power (non-vtec related)
Check your Dizzy Cap & Rotor, and plugs..
My old H23 started buck like mad trying to keep a steady speed at one point.. Ended up being the Dizzy, it's retardedly fubar'ed..
When I had my JDM H22A swapped in, the H23 Dizzy was reused and it started doing it again.. Just have to replace the Cap/Rotor and it's ok again for awhile.
Old Mar 10, 2009 | 05:34 PM
GraphiteMW's Avatar
The spark plugs and dizzy cap are pretty much brand new, which were replaced about 3 weeks ago. I will take a look at the rotor, I did end up ordering a new denso o2 sensor to see if that fixes the problem.
Old Mar 10, 2009 | 05:38 PM
MLBZ521's Avatar
kk
Well, my problem with the Dizzy is the little screw that holds the Rotor on the shaft is a little piece of junk. It'll come lose, or even fall off and then the rotor has play and will simply destroy itself and the cap.. :\
So I'd make sure that screw is tight at least.
Old Mar 10, 2009 | 09:10 PM
MikeLuder's Avatar
it's still prolly in the dizzy. the internal ignition control unit, inside. I would save and buy a new jdm internal dizzy... just do it. it will make it run waay better at least, but I've had a similar problem, twice, with my dizzy's.
http://www.kingmotorsports.com/category.aspx?cat=103
--- I would fork it out for the 'rich porter' high performance replacement.. either that or a new HONDA oem dizzy but they're twice as expensive as the 'rich porter'... i've gotten the 'basic' replacement twice now, (internal dizzy) and i'm ready to fork it out for an oem unit or the high performance dizzy. I even gutted my Jdm dizzy internals and put it inside the replacement & it ran better! Go Honda unit if you can..
Old Mar 11, 2009 | 09:27 AM
GraphiteMW's Avatar
Pulled the dizzy cap today and saw that the rotor has been chipped on several of it's fins.. damn it wish i didn't order that o2 sensor haha.
*Edit* replaced the rotor and everything is running great, thanks guys!!!!!
Old Mar 11, 2009 | 01:26 PM
HdeucedeuceA's Avatar
Originally Posted by MLBZ521
kk
x2 on this
I popped the hood one day to find the screw sticking through the cap.
Old Mar 11, 2009 | 01:48 PM
MLBZ521's Avatar
Awesome
I'd keep an eye out on that in the future.. Mine has done it three times now.. I think it's mainly the fault of the screw, but it could be the shaft it stripped also.. I'm not that sure on it.
I'm just going to replace the whole thing one day..
Originally Posted by HdeucedeuceA
x2 on this
LOL! Through the cap? Wow..
92LudeGuy
Jul 3, 2011 10:48 PM
702accord
Nov 18, 2009 08:05 PM
Preludeicious
Oct 2, 2005 08:41 PM
ramikassab
Dec 17, 2004 06:20 PM
Chubs
Mar 17, 2003 02:56 PM
