Just bought #01-0898! but.....
Old Mar 10, 2009 | 04:29 PM
4DRDB8GSR's Avatar
Default Just bought #01-0898! but.....
So after 5 months of looking for the perfect R, i just bought NHBP 01-0898, I flew to BWI Airport Maryland where the car and owner were waiting for me, counted out the new owners cash and drove it back 2700 miles to California nonstop... The caR was really strong across country and did awesome to get me back in record 'cannonball time'.
So i did an oil change with conventional 5w-30 when i got back and now the valvetrain is ticking and the rear main seal seems to leak oil. Should i do 3/4 carbon synchros at the same time, and what type of tranny fluid should i use? Is there anything else i should do while i have the tranny off?
Thanks all
Old Mar 10, 2009 | 04:38 PM
floatfisher's Avatar
Default Re: Just bought #01-0898! but.....
i would use honda mtf but if u have a mechanical problem oil wont make a difference
Old Mar 10, 2009 | 04:55 PM
CDUB's Avatar
Definitely use Honda MTF in the tranny.
Do you have any idea what oil was being used prior to you buying it? Conventional or synthetic? Rear main seals are a fairly common issue to ITR's.
Old Mar 10, 2009 | 05:11 PM
Asian G's Avatar
Congrats on the pick up!
Old Mar 10, 2009 | 05:24 PM
itr#1334's Avatar
pics man
Old Mar 10, 2009 | 09:08 PM
SiClone's Avatar
So why did you but it from that guy in Baltimore versus buying one in Cal? I thought there were more ITR's for sale in Cal, especially without rust...
Old Mar 10, 2009 | 09:55 PM
SuckMyDOHC's Avatar
Honda MTF and if its starting to grind, mix in a bit of GM Synchromesh Modified.
Old Mar 10, 2009 | 09:56 PM
racebum's Avatar
redline mtf has given me the best shifts out of what i've tried.
Old Mar 10, 2009 | 10:18 PM
jcizzo-R's Avatar
I just put in a 4.9 GearX final drive with 1-2 brass 3-5 carbon coated synchros the past weekend in my Itr. Used Royal Purple full Synthetic 5w30. Final drive whines a little bit..So far so good!!!
Old Mar 11, 2009 | 05:13 PM
4DRDB8GSR's Avatar
did you do the sleeves aswell, or just the synchros, im looking at the 3/4 carbon kit. how much should i expect to pay for the 3/4 synchro/sleeve install?
I have no idea what the previous owner used. The car is stored though, and i plan on rarily driving it, changing oil/filter every 2-3 months.
How much should i expect to pay for labor on the rear main seal?
Originally Posted by itr#1334
pics man
Too Scared of Theft.....its sealed and stored now!
ready now.....come try and get her....hehhehe
Thanks all
Old Mar 11, 2009 | 05:52 PM
jcizzo-R's Avatar
I just replaced the stock 4.4 final drive ring gear/counter with the GearX 4.9.
I also replaced all synchros 1-2 brass/3-5 Carbon coated (mine as well since the transmissions was out.)
The total for parts ONLY ran little under $800.00 The fd itself was $495.00
Synchros they sell 1-5($275.00) OR 3-5 but I'm not sure you might want to contact Synchrotech (EXCELLENT service!!).
Labor we did ourselves. By looking at this photo i took-you can imagine how much they'll charge lol
Old Mar 11, 2009 | 06:58 PM
jaa1311's Avatar
sorry to hear your having troubles with the car. the motor was rebuilt by JE Import Performance in baltimore, I remember when he had it done. I beleive the syncros were also done when the motor was rebuilt.
weird that it didnt leak on the drive back but is now leaking. no issues driving home?
Old Mar 12, 2009 | 07:57 AM
4DRDB8GSR's Avatar
yeah the motor sounds strong,
Good times! But I love this R! Never selling!!!!
Old Mar 12, 2009 | 10:53 AM
jcizzo-R's Avatar
hmmm, yeah the motor sounds strong, but he could not find any reciepts for the rebuild so I'm not sure what was done. I really doubt the synchros were done, because they're pretty bad, can't even shift vtec! The alternator did leave me stranded on the drive back home and cost a prest penny to tow, the motor leaked/burned tons of oil on the way back home, I'm sure there was 4 quarts of Lucas in there listening to the motor now... The clutch is right at the end and because of so many theft attempts immediatly I don't even drive the car....
Good times! But I still love the R! Never selling!!!!
Sounds like a rough start - Keep your chin up & eliminate it problem by problem.
GOODLUCK with the build..or REbuild lol!
Old Mar 12, 2009 | 11:38 AM
418whpturboD's Avatar
i have always used 5-30 mobile 1 in my jdm b16 lsd trans. it has been down a drag strip over 100 times at roughly 350 whp, and daily diven, with no problems at all..
Old Mar 12, 2009 | 01:14 PM
4DRDB8GSR's Avatar
Absolutely!!! it's all you can do!
So i'll just stick with OEM honda MTF. but what carbon synchros/sleeves should i buy? just 3/4 are bad. clutch/flywheel?...I would really like a 8-11lb flywheel and 6 puck sprung disc with a stock feeling pp... i've used 'action clutches'(not act) in the past with great results.
So maybe a CC stage 3 or Action 1KS clutch kit?
Old Mar 12, 2009 | 04:10 PM
SiClone's Avatar
Damn. Sucks to hear about all your problems.
Old Mar 13, 2009 | 08:14 PM
4DRDB8GSR's Avatar
Old Mar 14, 2009 | 07:00 AM
AndyD's Avatar
I had my car worked on at JE Import Performance in Baltimore. Worst shop experience I have ever had. He's the reason why I am the only one who works on my car.
Did you get a good deal on the car? Sounds like it has a lot of problems.
Old Mar 14, 2009 | 03:36 PM
4DRDB8GSR's Avatar
So i think I've decided:
Competition Clutch Stage 3 clutch kit - ($405)
8.4lb Competition Clutch steel flywheel - ($210)
Synchrotech 3rd and 4th gear hubs, sleeves and carbon synchros - ($250)
Toda dual valvesprings - ($360)
and new oem ItR retainers - ($50)
Old Mar 14, 2009 | 09:30 PM
Redcoupe's Avatar
Before tearing into all of that.
Take your sweet little red pcv valve off and see if it functions correctly. The stock pcv system on our b-series motor suck(no pun intended). I've seen these fail and cause oil pan issues, front seals and rear seals to go bad.
Before you tear into the transmission. I'd do a transmission flush and rebleed all fluids.
IT GUY
Honda Civic (2006 - 2015)
Nov 20, 2007 06:26 AM
Lucas_pln
Apr 17, 2007 06:06 AM
meagainsttheworld
40
Sep 5, 2006 02:52 PM
Brian-Brian
Oct 16, 2003 03:46 AM
AutoXsi2000
Mar 8, 2002 10:37 PM
