How to turn off SRS light???
Old Mar 10, 2009 | 03:09 PM
FRKWOO's Avatar
Default How to turn off SRS light???
i have a 2000 ek my radio fuse blew today so i went under my dash fuse box to get one of the spare fuses to use until i got replacements and i guess i accidentally fulled my srs fuse right next to the spares and now my srs light is on on my cluster and i was wondering how you get it turned off thanks ht!
Old Mar 10, 2009 | 03:14 PM
turboteg90's Avatar
pm for noodz
Default Re: How to turn off SRS light???
did you put the fuse back?
Old Mar 10, 2009 | 03:20 PM
FRKWOO's Avatar
yea i did
Old Mar 10, 2009 | 07:05 PM
FRKWOO's Avatar
anyone else?????
Old Mar 10, 2009 | 07:09 PM
teamworxek9's Avatar
take the bulb out of the cluster, or just unplug the yellow plug at the cluster.
Old Mar 10, 2009 | 07:12 PM
FRKWOO's Avatar
i dont want to get rid of it i want it off i heard you can only turn it off if you have the dealer do it?
Old Mar 10, 2009 | 07:15 PM
SiTR's Avatar
GoT the same problems but mine just turned on alone. Whats the proper way to turn it off?
Old Mar 10, 2009 | 07:23 PM
TSXecutive's Avatar
Since you put the fuse back, try disconnecting your battery for a few minutes to let the ecu reset then hook everything back up and turn your ignition on if that doesn't work, I know there is a thread somewhere that says how to reset the light on your own. If it is not in this forum I know it is in another I just can't remember which one it is at the moment. Otherwise you can just take it to the dealership and have them do it there.
Old Mar 10, 2009 | 07:26 PM
FRKWOO's Avatar
i tried the battery......
tn_90's Avatar
New User
If that doesn't work, I highly recommend you take it to the dealer ship
Old Mar 10, 2009 | 07:27 PM
1LowSol's Avatar
Originally Posted by tsxecutive
since you put the fuse back, try disconnecting your battery for a few minutes to let the ecu reset then hook everything back up and turn your ignition on
+1
Old Mar 10, 2009 | 07:35 PM
FRKWOO's Avatar
Originally Posted by 1LowSol
+1
jus tried....didnt work....thanks for the help!!
Old Mar 10, 2009 | 07:41 PM
1LowSol's Avatar
My bad, I was reading threw the post when you replied and said you tried it. I dunno then unless you have something unplugged somewere. Have you checked all the plugs?
Old Mar 10, 2009 | 07:46 PM
FRKWOO's Avatar
yes i have havent messed wit anything lately only the fuses
Old Mar 10, 2009 | 07:51 PM
civicsi940's Avatar
i forget but there is a scanner that will tell u what is wrong with the srs system but i assume the dealership will do the same thing. i did the battery thing but i hit a bump on the crappy roads in the city and it came back on. so i am in the same situation u are in bud. i am taking mine to get scanned fri. or sat. at my local shop and see what the problem is
Old Mar 10, 2009 | 07:52 PM
FRKWOO's Avatar
can u do it at a shop or is it only dealership?
Old Mar 10, 2009 | 08:06 PM
toner297's Avatar
in order to reset the ecu you not only have to disconnect the neg cable on the battery but also pump your brakes until it get hard to push in the wait 5mins hope that helps
Old Mar 10, 2009 | 09:31 PM
FRKWOO's Avatar
^^^ jus tryed no luck.......
Old Mar 10, 2009 | 09:50 PM
tazeat's Avatar
http://lmgtfy.com/?q=civic+reset+srs+light
Old Mar 10, 2009 | 09:58 PM
raidacaipo's Avatar
Originally Posted by tazeat
dude that is an awesome link.. now find me naked ladies
Old Mar 10, 2009 | 10:13 PM
tazeat's Avatar
http://lmgtfy.com/?q=naked+ladies
Old Mar 10, 2009 | 10:18 PM
raidacaipo's Avatar
lol
Old Mar 11, 2009 | 08:31 PM
toner297's Avatar
does it really work id hate to have my air bags pop
Old Mar 11, 2009 | 08:39 PM
raidacaipo's Avatar
yes it does.. just make sure all the srs units are plugged back in.. then you reset it.. it only works on certain cars though.. good luck
kelviiv
May 18, 2008 10:22 PM
Civic92Turbo
Oct 14, 2004 08:13 AM
LB CRX
Aug 21, 2003 01:45 PM
EGkTiOn_CiViC
Aug 30, 2002 06:03 PM
