No power!!! Help!!
Old Mar 10, 2009 | 12:55 PM
xasiansupermanx's Avatar
Default No power!!! Help!!
went to turn over my 1996 Honda Civic EX Coupe and sadly did not start nor crank. the cluster lights dosent even come on. i try turning the flashers on and NOTHING.
-Battery GOOD (even try jumping)
-CABLES are good to Main Fuse box, Good to starter.
-Check EGNITION GOOD
BASICALLY NOTHING WORKS AT ALL!!
HELP!!!
Old Mar 10, 2009 | 12:58 PM
Former User's Avatar
Default Re: No power!!! Help!!
If necessary clean and tighten the battery connections and its ground wire on the chassis.
Check for blown fuse 41 (80A) and 42 (40A) under the hood.
Old Mar 10, 2009 | 12:59 PM
rick_rabies's Avatar
I'm not Rick!
try the ecu fuse, mine did that. check all fuses and tap your starter with a wrench
tekknition
Jun 14, 2008 09:17 AM
mar778c
Mar 1, 2008 05:49 AM
ITR9788
Oct 13, 2005 01:34 PM
Train
Jun 2, 2004 08:15 PM
ILOVEGIRLS
Feb 23, 2004 03:30 PM
