Rear discs!
SO should I change EF DX master cylinder and booster for DA cylinder and booster? I noticed people do this who get rear discs. Why? and what if I dont? I have Parts for it any ways just dont noe why I should do it
I didnt do it at first. You will be fine without the booster/mc. You just won't have the best brake pedal feel. If you already have the parts and have to drain the fluid for the swap just go ahead and put them in. It will feel alot better.
you dont need anything but the rear trailing arms to complete the swap. but if everything is laying around do everything at once. because youll have to bleed the brakes
Ok yea cuz ever since I swapped my front brakes my brake pedal feels like ****. I still haven't done rear but I guess I should swap MC and BB too then. Will pedal feel stiffer? and is it hard to swap BB? Do I have to take DASH apart? I need to eventually take dash apart because I am installing A/C crap that goes behind dash (have those parts too that I took off DA) but if i need to take of dash for BB then might as well do it all at once. Oh and after replacement of master cylinder and BB do I have to bench bleed master cylinder? Or do I just bleed at all four wheels?
ok so my question didn' t get answered. Do I have to take dash apart to replace booster? and once replaced do i have to bench bleed master cylinder? or do i just bleed at all four wheels?
saveacivic
Suspension & Brakes
Jun 18, 2010 09:55 PM
Markb16a
Jan 1, 2008 02:17 PM
nefariousyellow
Oct 21, 2007 08:00 PM
