car heating up?
Old Mar 10, 2009 | 11:03 AM
miggyi's Avatar
Default car heating up?
So I had been noticing a smell every time I got out of the car. It was like a rubber smell kinda like the smell of tires. But then I started noticing it was coming from under the hood and it seems like the engine is hot. What could be causing this and how can I fix it.
Old Mar 10, 2009 | 02:12 PM
h224thgensedan's Avatar
Default Re: car heating up?
Is there anything touching your header, pulleys, axles, ect. Also how do your belts look
Old Mar 11, 2009 | 10:27 AM
miggyi's Avatar
I think the rubber smell is the timing belt. Because when im driving I can hear like some squeaking which sounds like the belt... also the smell seems to be coming from the belt area...what could be happening?
Old Mar 18, 2009 | 02:21 AM
hatchlover71890's Avatar
Icon3 Re: car heating up?
more than likely you spilled some antifreeze on your header this will stink for quite some time trust me, even the smallest bit, even water on the header will make a smell it sucks....
Old Mar 18, 2009 | 04:30 AM
dephtone's Avatar
Well it could also be like your alternator pulley belt or Power steering belt ( if applicable). The belt itself might be dry rotted and just shot. Most when they get pretty bad they start squealing and you might smell a hit of that rubber smell. The timing belt wont squeal. It will just snap if its going to break. Since it has slots for the teeth to go in Im pretty sure the timing belt wont slip and squeal..It's more than likely an accessory belt, Alt, Power Steering, AC etc.
lankan-balla
Mar 8, 2013 01:02 PM
dvgleyzer
Jul 19, 2011 06:29 PM
NikeSB
Sep 14, 2006 04:23 PM
Project_ED8
14
Mar 10, 2004 09:20 AM
MeanGreenEG9
Apr 9, 2003 07:38 PM
