B18a1 92-93 obd1 in to ef help!
I am loosing it. I have a b18a1 obd1 motor cable tranny.
I took this out of a 92 4dr auto to manual converted.
I have all the mounts from that swap I want to put it in my 89si.
I need some help!
I was told I can use all the mounts from the integra into the ef.
I looked it over and they seem to be the same locations can anyone verify before I take out the motor out of the ef.
any info would be much appreciated.
I need some help!
You need a mount kit. If you use the 90-93 Integra stock mounts, you need to relocate the chassis brackets in the engine bay. Unless you have an EF8/9 SiR engine bay, the Integra stock mounts will not work.
Otherwise, cut & weld the frame brackets to their new location (so 1995) and that will work.
pouponu
Jan 31, 2008 08:38 PM
