PASSJDM PLUG & PLAY harness compatible with JDM OEM HID??
Old Mar 9, 2009 | 06:45 PM
Pr-Type-R's Avatar
Default PASSJDM PLUG & PLAY harness compatible with JDM OEM HID??
does anyone know if theyre compatible??
http://passwordjdm.com/PasswordJDM-D...P1769C320.aspx
Old Mar 9, 2009 | 06:49 PM
Devon M's Avatar
Default Re: PASSJDM PLUG & PLAY harness compatible with JDM OEM HID??
Just call them, they're always helpfull.
Old Mar 10, 2009 | 09:12 AM
JDM 98 GSR's Avatar
no it is not. all it does is makes your highbeam plug and play and it has 2 wires to wires your fogs and city light. i called them and asked if it would work with my OEM HID front end and they said yes "plug and play" and it wasnt
Old Mar 10, 2009 | 10:39 AM
Spids5's Avatar
Don't judge or question
JDM 98 GSR is right, it does not have the wire for the low beam (HID) but you can easily add another wire. When I did my headlights I bought a similar harness from them that didn't come with the black plug. I pulled two wires out of my old connectors and added them to the new connectors. In my wiring thread it has a walk through of how to do it.
https://honda-tech.com/forums/lighting-107/how-jdm-itr-hid-headlight-fog-light-wiring-2195061/
Old Mar 10, 2009 | 12:25 PM
Pr-Type-R's Avatar
https://honda-tech.com/forums/showthread.php?t=2195061
Great write up! ill most likely follow it. so is it worth it to buy the Harness? because i have the OEM Male plugs for the Headlights..?
Old Mar 10, 2009 | 01:46 PM
Spids5's Avatar
For me it was because my plugs were messed up and the wires were hacked so I decided to start over. If you have decent plugs and can find the extra gold connector then I wouldn't buy the connectors from PW JDM.
Old Mar 10, 2009 | 06:15 PM
VTEC_Club's Avatar
I bought the harness. Thought it was a total waste of money.
Old Mar 10, 2009 | 08:56 PM
JDM 98 GSR's Avatar
wiring the headlights and everything is alot easier then people think if you sit down and look at the headlights and your car youll be fine. im using the harness for my high beam, fogs and city light and i just wired my oem hid's myself so i would say it wasnt a total waste
AGen2integra
Lighting
Mar 28, 2016 04:37 PM
BOTAN01
Feb 2, 2008 10:59 AM
Mike M
Aug 17, 2005 11:51 PM
xintegr
Aug 10, 2005 06:46 PM
Ideal R
Apr 17, 2003 07:06 AM
