valve cover stud snapped
Old Mar 9, 2009 | 06:30 PM
webbs2jzgte's Avatar
Default valve cover stud snapped
ok i have a issue where the valve cover bolt that holds it down snapped on me. am i going to have to get a new head to drill and tap that out and try to get a stud that will fit it and ghetto rig it.
heres a pic of the aprt im talking about
Old Mar 9, 2009 | 11:52 PM
subway's Avatar
Default Re: valve cover stud snapped
Drill it out and get one from Honda. Those studs are really soft and will break easily if you turn it too hard. =\
Old Mar 9, 2009 | 11:56 PM
DC206R's Avatar
or you can take the VC off, then take it out that way. mines snapped off too, i've jsut been lazy to do it.
Old Mar 10, 2009 | 12:17 AM
LiEkjAi's Avatar
use this tool call "easy out" and replace it, like what subway said, the stud are easy to snap off if you over tighten it
Old Mar 10, 2009 | 04:41 AM
JDM 98 GSR's Avatar
that stud is like $6 from Honda
Old Mar 10, 2009 | 08:58 PM
ok does anyone know the ft/lbs they require.
Old Mar 10, 2009 | 09:06 PM
DC206R's Avatar
i think somebody said 8 lbs. but it really doens't matter jsut tighten it enough.
Old Mar 10, 2009 | 09:15 PM
ok. cus this stud snapping would cause the valve cover to not set proprely correct. causing a leak in oil correct?
Old Mar 10, 2009 | 09:31 PM
JDM 98 GSR's Avatar
correct
Old Mar 10, 2009 | 09:32 PM
ok cool thanks for the info everybody. ill jsut stop and get a valve cover gasket whil eim at it
liljohn850
Jun 5, 2009 04:23 PM
Import Prelude
Apr 18, 2007 02:50 PM
Si_chRis
18
Jul 5, 2006 05:25 PM
BDogggUT34
Apr 22, 2005 03:12 PM
JDM_lover03
10
Oct 19, 2004 07:06 PM
