Cam experts needed jdm b18c/crower
Old Mar 9, 2009 | 04:32 PM
civic93@8psi's Avatar
Default Cam experts needed jdm b18c/crower
the cam part # is 63401-2 grind number is custom.
advertized cam specifications
intake duration 304* lift .448
exhaust duration 306* lift .417
based on rockerarm ratio 1.55 intake and exhaust
lobe seperation is 107*
duration @ .050
intake 240* .289
exhaust 233* .269
is this cam good for my setup. car will be tuned on cromepro
what should i expect out of these in a jdm b18c skunk2 intake manifold dc header in a em1?
also can i get away with stock valvetrain??
thanks
Old Mar 10, 2009 | 04:41 AM
Default Re: Cam experts needed jdm b18c/crower
no 1????????????
Old Mar 10, 2009 | 06:42 AM
hmoobhero's Avatar
theres no specify answer to your question. where did you get them? did it tell you to upgrade your valvetrain? whats the lift in mm? every motor runs different. the only way is to put them in and test it out.
Old Mar 11, 2009 | 03:08 PM
Rocket's Avatar
230+ duration @ 0.050 requires a good tuna (NOT TWEAKER).
A stock map is going to hate the low vacuum and you'll sputter and foul out your plugs in about 30 seconds.
Old Mar 13, 2009 | 07:09 PM
cams are in running on stock si ecu for now it runs pretty good considering its obd2
Old Mar 13, 2009 | 10:09 PM
racebum's Avatar
this is 100% true. i ran a pair of these cams on a p73 ecu and could not get the car to run remotely right at idle without a vafc to hack the map signal. it's PIG rich at idle. spend the money on a real tune.
Old Mar 13, 2009 | 10:38 PM
Rocket's Avatar
Sorry I mis-read the title. Thought it was B18B LS.
63401 is almost stock replacement, hence runs well with stock ecu.
Old Mar 13, 2009 | 11:17 PM
racebum's Avatar
so you have used this cam in a setup? about how many inches of vacuum were you seeing?
personally, i think you're full of sh*t
i've used this cam. they are rich at idle on a stock ecu from slightly less vacuum.
Old Mar 14, 2009 | 10:05 AM
DonF's Avatar
LOL. i have used them and found the 1-2 degrees of duration and the .002 thou. more lift over stock "R" cams means nothing to the stock "R" ECU in idleing. Of course I had an advantage they were properly installed. I could figure out how to align those funny little marks on the cam gears, and all the valves were seating.
Old Mar 14, 2009 | 11:22 AM
racebum's Avatar
ouuuuuuuuch. well, i did kind of ask for that
Old Mar 14, 2009 | 12:36 PM
it kinda seems as if its missing or lobing at idle other than that the stock obd2 si ecu is doing ok.. im going to put a itr map in a p28 and take out a lil timing until my tuner can fit me in..
Old Mar 14, 2009 | 01:02 PM
DonF's Avatar
A stock obd2 si map is not going to work.
Old Mar 14, 2009 | 06:08 PM
but it runs pretty good off idle(1100 to 8000) but it feels like its more left in it.. its a far bit faster than a my old black 00 si stock block i/h/e same ecu... i think my p28 is bad i tried like 5 diff maps none worked, then i tried my friends jdm p72 ecu and it ran good on lo cam but vtec would not come on..(my friend always messin w stuff added a wire straight from the jdm ecu circut board 4 vtec cause he has a DA instead of pinning the wire in the connector,dumb huh )
Old Mar 14, 2009 | 09:06 PM
Rocket's Avatar
Threads like these show how ****tards have killed H-T. It's like whack a mole, hit one on the head and more pop out.
Go back to reading SA perf books. You'll be able to get 230whp on 15lbs of boost with the "hot" setup.
Old Mar 14, 2009 | 10:03 PM
UncleD's Avatar
Originally Posted by master of the universe
it's like whack a mole, hit one on the head and more pop out.
lol!
Old Mar 14, 2009 | 10:19 PM
Combustion Contraption's Avatar
If only the real world worked this way.
"Pool Cleaning experts needed"
"How can we help?"
"My pool is really dirty, I tried dumping some plain dishwasher soap in there. any ideas?"
"Yeah, that wont work, you need us to do a pro job. It will be $150"
"but the dishwashing soap seemed to work just fine. any more opinions? ?"
Old Mar 15, 2009 | 07:21 AM
hold up now we got e-thugs. u guys are so cool.
Old Mar 15, 2009 | 12:37 PM
Actually, e-thugging would be if we were acting hard, or physically threatening you. All we're doing is shining the light on stupidity. Have a nice day.
Old Mar 15, 2009 | 01:01 PM
anothersickhatch's Avatar
truth. i wonder how it is possible that any honda motor can still run with the sh*t ive been reading.
Old Mar 15, 2009 | 01:51 PM
Rocket's Avatar
Oh I fogot whatta nice guy "ICrashSideWays" is. He gets a big "Atta Boy!!" for mis-information.
It takes alot of work to keep the clarity of the knowledge pool/puddle here from becoming a complete cesspool.
Fighting Mis-information fo da win!!!
Old Mar 15, 2009 | 04:13 PM
FlatBrokeHatch's Avatar
"How can we help?"
90% of HT threads in the past few years. ^^^
Old Mar 15, 2009 | 05:37 PM
C_Rock77's Avatar
E-Thugs? Combustion Contraption and Master of the Universe are 2 of the most knowledgeable people ON this board. Excuse the f*ck out of them if they don't want to go along w/ the bull$hit that happens on this board.
They gave you their opinion....doesn't seem like the claims made by Greddy on the cams probably aren't worth the paper they're printed on.
Just b/c you don't like the advice given, doesn't mean it's not good advice.
Old Mar 15, 2009 | 06:00 PM
never said it wasnt good advice! just didnt hafta be an ******* about it. so excuse the **** out of me for having a question b4 i started my engine and posting what was goin on after starting my engine...
Mike K
Mar 12, 2006 08:44 AM
knxtnh22accord
Jan 10, 2005 09:11 PM
crower_h22a
Jul 29, 2004 02:50 PM
skribblah
Sep 13, 2003 07:07 PM
bananacruzier
Feb 3, 2002 09:40 AM
