Normal burning oil 2qts GSR?
wow. that sucks...mines don't even eat as much oil as that. and it has 160k on it. well mines don't even burn oil or eat oil at all really its always at the good level
so you think i will blow engine or should i replace the valve cover gasket and all first befor i go thinking about a new car. im low on budget bad.
Don't even think about a rebuild; that's pointless. Waste of money. Forget it. Checking your oil level every time you fill up with fuel and topping it off as needed is much cheaper.
As long as you keep the sump full of oil, you'll be fine. Just don't let it drop more than a half quart low.
My 94 GSR burns zero oil with 148,xxx miles. It would kind of worry me personally, but if you can live with it then just monitor it and make sure it doesn't get progressively worse.
could it be cheap oil from ac&t is why it burned away so fast... it doesnt smoke at all and last time i check compression it was 220- accross. im hoping the compression is the same tommorow whats some good numbers to hope for!?
like i said i am not sure i am BURNING OIL..... im running a compression check today. i dont think its possible for my car to burn that much oil and NOT smoke at all so something is not right. after driving the car for ten mins. i let it cool for about 30 mins then check it maybe i should have waited longer?
well, if you pour in 4qts when you do your oil change, and when you check it at some point later it is lower than the upper dot on your dipstick that means you've lost some oil. whether it is burnt or just leaked out, is the question.
