Cruise Control on LS
Whats up everyone, just got a quick question i need some more people to make clear for me. My cruise control is not longer hooked up anymore but is still in my engine bay and I wanna remove it, but the wire from the cruise control module goes into the fire wall then i think has another wire that attaches to the gas pedal. If i disconnect the piece from the back of the firewall and then from the pedal nothing will happen correct? Its just set up for the cruise control? thanks everyone.
My EF
My EF
You can pull out the Cruise Control Module (= the CC's brains, a.k.a. "Cruise Control Unit") in the driver's footwell, if you want, too. Unplug its harness and unbolt it.
Ok so from the cruise control a wire goes to the fire wall then at the pedal there is the metal wire i can cut the wire from the pedal then just pull the whole thing out and just put the plugg in.?
I understand what You told me I just wanna make it all clear if i cut the cruise control wire and i dont wanna use it anymore it only effects the cruise control nothing else?
from the cruise control a wire goes to the fire wall then at the pedal there is the metal [cable] i can cut the wire from the pedal then just pull the whole thing out and just put the plugg in.? I understand what You told me I just wanna make it all clear if i cut the cruise control wire and i dont wanna use it anymore it only effects the cruise control nothing else?
I installed OEM cruise control in my 93 Civic DX this past fall and spent a lot of time looking at the 88-91 Civic setup, too.
ok awesome, yea right now I have the green clip un done and it rides fine. I looked at the pedal wire do u know what took i can take that off with? It looked like a weird bolt
It is a bit tricky. I recommend:
1. Disconnect the actuator cable at the actuator itself. It should be pretty self-evident how to do this. Disconnecting the cable at the actuator end gives you slack to work with at the pedal end. Note how the cable stop attaches at the actuator. It will be a bit similar at the gas pedal.
2. Go into the footwell with a flashlight. Examine where the cable connects onto the gas pedal.
3. At the gas pedal, you should be able to rotate the cable stop and then push it either inboard or outboard so it slides out of the pedal fitting. Worst case there is a fairly easy to release clip holding the cable stop in place. Note: You should not have to cut the cable. That's a desperate measure.
4. Once the cable stop is slid out of the pedal fitting, pull through the firewall and store, discard, whatever.
This might help a little bit. Look at part #9. You might need to remove the clip, part #15.
ok I have been under the wheel for a while and cannont figure out how to get the lil white circle that it attached to the top of the pedal. I keep pushing it back and forth and it wont come out !!!!!!
VADERS_EM2
Oct 25, 2008 05:51 PM
