skunk 2 stage 2 cams help
im currently looking for reliable cams for daily gsr and i have been reading up on the skunk2 stage 2 cams.
i just want to know if i would have to upgrade any of my valve train since its on stock valve train and numbers i would be close to dyno'ing at.
my current setup is
97 gsr port and polished head
blox intake manifold
edlebrock tb
dc sport headers
full two and a quarter exhaust
my current setup is
edlebrock tb
dc sport headers
yea, you definetly have to upgrade them because those cams will make power past the gsr stock redline.
also, you dont have to change your header and exhaust. yes, you will get more power, but not necessary. plus, get a tune. tuning will get you alot of power. gl man.
With stage 2 cams you will need to have the car tuned to get the power and the drivability out of the cams. The idle will need to be bumped up and the fuel map will need to be adjusted. As stated before, you will need to upgrade the springs and if you have the $$$ the retainers. Throw in a set of gears and you could see numbers around 180-200 WHP.
The stage 1 cams will be easier for a DD and you will still get number in the area of 180 WHP and you will save money by using you stock valve train parts.
*The number provided are assuming you have a good port job, and tune. As I do not know what you compression you can also get a thiner head gasket.*
I installed these in my friends gsr powerd ek and no you don't need to replace your valve train. He is using the skunk2 intake mani along with the 64mil skunk2tb. He installed a jdm type r ecu(5600 vtec) which got rid of mid rpm bog. This setup was run at the track (road coarse) a few times last year and works great. Without using a larger tb/mani, you may experience a slight bog from takeoff(stated by skunk2). I've seen/heard of these engines bouncing off 9000rpm all day long. Btw, his motor made 180whp before the cams and tb upgrade. We are now upgrading the springs and retainers since he is now going with a turbo setup.
You can run the stock, but the stock, non type r heads, were never meant to see revs above 8500 rpm for an extended period of time. I have seen three cars in my shop who believed they could run the stock parts after I advised them to swap them out and now we are rebuilding the motor.
I run the same cams in my street car along with the skunk2 pro springs and have never had a problem. I run the car out to 9500 rpm all the time when i on the track.
would pro 2's be to much for daily driving, i drive about a mile to work and a mile back, i see the track maybe 1 time a month in the summer, or should i get the pro 1's im not lookin for 200whp but i do want to run 13's in my DA so i hope the pro1 can do that for ls/vtec with p30's
