help with timing belt...
Old Mar 9, 2009 | 11:05 AM
JDMTOKER's Avatar
Default help with timing belt...
ok...I don't have an air compressor right now because i don't have 220volt wires ran yet...but on to the question...how can i keep the crank from rotateing so i can get the crank pully bolt off??????any solutions or advice please help
Old Mar 9, 2009 | 11:14 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: help with timing belt...
Easy... take the starter off or the transmission dust shield and put a screwdriver through a hole in the flywheel/flexplate. Depending on if you have an automatic or manual transmission you could leave it in gear with the tires on the ground and turn the wheel all the way left and do it that way too (as long as your drivetrain is in decent shape/parking pin isn't stripped LOL).
Old Mar 9, 2009 | 12:24 PM
DRAMA's Avatar
besides leaving the tranmission in gear, use an extension on the rachet like a strong hollow pipe you can slide over. this will give you better leverage to loosen the pully bolt.
Old Mar 9, 2009 | 12:27 PM
JDMTOKER's Avatar
last question is it regular thread or revearse threaded...thanks...I just went and got the tool from the snapon man just wanna know which way the bolt turns...thanks for the info though i was thinking of doing both of these ideas until the snapon man told me he had a tool just for this job
Old Mar 9, 2009 | 12:53 PM
Dark_Teg's Avatar
Regular thread
bretthuff0
Dec 29, 2010 12:28 PM
redm3turbo
Aug 19, 2009 01:11 PM
mikecel79
Aug 26, 2002 09:52 PM
AmauryR
Jan 22, 2002 01:48 PM
D-SPEED
Sep 2, 2001 08:04 PM
