side draft question
Old Mar 9, 2009 | 09:33 AM
Jesseking24's Avatar
Default side draft question
I have a d16A1 from an 86 integra in my crx. It currently has sk racing dual side draft carbs I'd like to buy rebuilt webers but need to know how to set them up, so I can tell the builder. Anyone know the correct jets/chokes etc? I want driveability, (decent idle) not speed. Thanks.
Old Mar 9, 2009 | 09:38 AM
jlicrx's Avatar
Default Re: side draft question
which Webers are you going to use? we run 45DCOE's on our DOHC ZC
Old Mar 9, 2009 | 09:44 AM
I was thinking 40's because I've heard they will idle better. I forgot to mention it has a pacesetter header, but factory crx exhaust, which is maybe 1.5 inch. I know very little about carbs, so I was hoping for the easiest set up, and most broad driving range. Thanks a lot.
Old Mar 9, 2009 | 09:54 AM
jlicrx's Avatar
we tried 40s on our ZC and they weren't big enough, so we went to the 45's with 38mm venturis - we do have stage 4 camshafts and our is a ZC - the 86 D16A1 was not quite as powerful as the ZC, so 40s may work fine for you
i would start with the Weber factory baseline jetting and work from there - it should be real close
40 DCOE
Main Venturi--------- 32
Auxiliary Venturi---- 4.5
Main Jet--------------- 115
Emulsion Tube------- F11
Air Correction Jet--- 200
Idle Jet---------------- 45F9
Pump Jet------------- 40
Pump Exh----------- 50
Needle Valve------- 1.75
45 DCOE
Main Venturi--------- 36
Main Jet--------------- 145
Emulsion Tube------- F16
Air Correction Jet--- 155
Idle Jet---------------- 55F8
Pump Jet------------- 45
Pump Exh----------- 40
Needle Valve------- 2.00
Old Mar 9, 2009 | 10:10 AM
Thank you so much! Question. When you swap a d16 into a first gen crx the engine is slightly cocked toward the front of the engine bay. This creats a 5-10 degree upward angle(I'm guessing) on the sidedraft carbs. I know this isn't ideal, will it run okay.
Old Mar 9, 2009 | 10:41 AM
jlicrx's Avatar
ours is tilted slightly to the front also - doesn't seem to be a problem for us
sixgunsound
Jun 13, 2008 02:14 PM
Ex-Eg-Driver
Oct 10, 2007 05:51 PM
LorenGeist
Aug 15, 2004 06:54 PM
90SICRX
May 12, 2004 08:51 AM
91teg
Feb 5, 2004 03:54 AM
