Wilwood 6 piston kit installed on ITR w/pics
See link for pics of the kit installed.
https://honda-tech.com/forums/suspension-brakes-54/wilwood-6-piston-kit-installed-itr-w-pics-2519616/
Pics added below.
Pics added below.
Sorry for the Link. It was late and I wanted to get it done before I passed out.
Everything bolted up with no problems. I did have to use some washers that came with kit to get the caliper centered on the rotor but other then that it was a direct swap.
From what I was told, this is the first kit for the ITR that Wilwood has sold. I'm waiting on the rear kit to be complete now.
Here's the pics.
Here's the pics.
has this setup been tested? i have a friend that installed 6 piston wilwood brakes on his acura CSX, and he said he got better results from the stock brakes and HP+ brake pads...
Not sure how much testing was done but it's hard to believe that it won't make an improvement. I have not had a chance to put them to the test yet.
I know its more then I need but I needed new rotors and my calipers were rusty anyways.
What do you have that matches in the back? Wilwood? Show pictures of that.
Did you delete the mechanical (parking) brake? Does Wilwood, et. al., offer a mechanical add-on for rear brake?
The rear kit is not ready yet. I'm on the list to get it when they figure out the park brake bracket. Everything else is ready but they are doing R&D on the park brake bracket mounting as we speak. I was told it should be ready in the next 2 months.
i wouldnt mind running a 20mm spacer if needed.....the wheels are also 16x7 50+ offset however the spoke design might have some influence on the fitment...could you measure the distance from the hub to the edge of the caliper?
This is what I used to measure before buying the kit.
People can argue about this all day long. The Spoon callipers are controversial because people will tell you that they do not really provide better braking...just better brake feel and the possibility that you'll avoid cooking conventional brake fluids.
The Spoon callipers even use the same size brake pad as the OEM brake callipers.
I have always been curious about what causes people to make changes to the brake systems of the DC2 ITR. My car is a track car, only driven to and from the track. It frequently has to haul down from speeds in the 135-140 range, repeatedly over a 20-30 min period, and I have not really felt compelled to have to make changes to the brake system.
Not looking for a fight, but I'm honestly curious why we make changes to the OEM brake system.
