Wheel Spacers reduce camber?
Old Mar 8, 2009 | 07:50 PM
4serioferio's Avatar
Default Wheel Spacers reduce camber?
I am wondering what anyone knows about wheel spacers reducing camber?
My friend just got a car same year as mine but a coupe, and his car is lowered almost the exact same as mine, just barely tucking tire, only he has wheel spacers and the camber is almost non-existent.
I'm wondering if anyone else knows of the benefit of wheel spacers for this condition?
And whats the safest size without having to mess with the lugs.
Thanks
Old Mar 8, 2009 | 08:58 PM
trustdestruction's Avatar
Default Re: Wheel Spacers reduce camber?
wheel spacers won't fix camber
if you want to fix camber, you need a camber kit. and for the rear you can either do the washer trick or get a camber kit.
Old Mar 8, 2009 | 09:13 PM
Weifast's Avatar
Just get a skunk2 camber kit, reasonable price and gives you adjustability. They work just fine, minus the squeak you get from the polyurethane bushings -_________________-
although the squeaking is only temporary until it breaks in.
Old Mar 9, 2009 | 01:22 PM
Okay, I was just wondering.
I'm looking for camber kits, and this guy I was talking to has front an rear for $120 some brand he got himself right in Taiwan (hmm...?)
But I really only need front, I have little to no camber in the rear, what is the washer trick however?
And do you know if a rear tower brace from a hatch will fit a sedan?
as well as a front lower H brace?
Old Mar 9, 2009 | 01:44 PM
94EG8's Avatar
Seagull Management
The washer trick involves removing the 2 bolts the hold the upper control arm to the unibody and putting washers between the upper arm and the unibody, the bolts should be replaced with longer bolts to compensate for the length of bolt lost due to the washers.
Old Mar 9, 2009 | 03:06 PM
DRAMA's Avatar
Wheel spacers just push out the wheel, leaving it at the same angle (camber).
Washers and longer 14mm bolts (PS or AC bracket bolts) will do the trick.
Old Mar 9, 2009 | 05:46 PM
It sounds like replacing bolts would be rather pricey.
Whats the average cost of doing that?
Old Mar 9, 2009 | 05:51 PM
what???
go to the hardware store and buy bolts. lol it'll cost you like $5 total for everything you need
Old Mar 9, 2009 | 06:04 PM
94EG8's Avatar
Seagull Management
Uhh, no...
Pretty much nothing, thats why everyone does it instead of buying a rear camber kit. Like the guy above me said go to the hardware store, buy some bolts and washers.
Old Mar 10, 2009 | 07:56 AM
Aha, I thought you meant replacing the lug studs....
Old Mar 10, 2009 | 03:46 PM
well that wouldn't be expensive either.
Old Mar 10, 2009 | 08:00 PM
It wouldn't?
Getting longer bolts (what should I call these???) that you lug your tire onto wouldn't be very expensive???
Old Mar 10, 2009 | 08:02 PM
It wouldn't?
(wheel studs)
nah, they're not that expensive.
Old Mar 11, 2009 | 10:15 PM
(Thanks)
Not that I need longer wheel studs, now I am just wondering how much it would cost, and how you install them.
Is it a do it yourself job? I also assumed changing the studs would be a serious labor job.
Old Mar 11, 2009 | 10:25 PM
Yes. It's not hard.
http://www.hondacivicforum.com/forum...ad.php?t=19175
Old Mar 12, 2009 | 10:13 PM
Oh that's not bad at all. Accept grinding down the bolt doesn't seem all that safe...
Any write-ups on how to do this washer trick?
Old Mar 12, 2009 | 10:16 PM
I think there's a link to the write up in the FAQ.
Old Mar 14, 2009 | 02:51 PM
Not that I found. Looked at some stuff on Google, definitely an easy DIY.
I just need to make sure: when adding only 2 washers behind each bolt is it okay to keep the original bolt?
Old Mar 14, 2009 | 02:57 PM
Pothole987's Avatar
its best to get longer bolts.
http://www.ej8squad.com/thread-5157.html
Old Mar 14, 2009 | 03:04 PM
Targa250R's Avatar
be professional
I'm looking for camber kits [...] But I really only need front
Why?
Old Mar 14, 2009 | 03:07 PM
yes, stock bolt will work
Old Mar 14, 2009 | 03:41 PM
Okay, great thanks man!
Old Mar 14, 2009 | 08:22 PM
I picked up 8 washers today, planning to use 2 per bolt, a reasonable amount for a sub 2 inch drop.
I took pictures, it did virtually nothing. So I plan to pick up 4 new, longer 14 mm bolts and add an additional 2 washers per bolt.
Here are the crappy cam phone before and after:
Before:
After:
UrbanAdolescent
Suspension & Brakes
31
Sep 8, 2010 07:16 AM
NWaccord
Suspension & Brakes
12
Dec 9, 2009 08:36 PM
th34nt0ni0
Suspension & Brakes
Dec 21, 2008 02:15 PM
zbra09
Suspension & Brakes
Oct 5, 2008 07:41 AM
d8168055
Nov 29, 2002 08:41 AM
