On car valve spring tool
Old Mar 8, 2009 | 11:44 AM
Lewy. Dee Ayy's Avatar
Default On car valve spring tool
Hey, im going to be installing a set of duel valve springs and retainers on my LS (b18b) pretty soon.
and i want to do it without removing the head from the car
i have found a tool that will work on vtec motors. but i am unsure if it will work on an LS motor
so im trying to find out what everyone else uses/used when installing them on there ls motor
sorry if this is the wrong section to be asking this question. if it is please delete or move to the correct section
thanks in advanced for any help.
Old Mar 8, 2009 | 12:25 PM
insidiouseg-6's Avatar
Default Re: On car valve spring tool
the tool i have only works for vtec heads and wont bolt into a ls head
Old Mar 8, 2009 | 12:29 PM
Combustion Contraption's Avatar
It would really help if we knew what tool you were using.
Old Mar 8, 2009 | 12:52 PM
this one!
Old Mar 8, 2009 | 01:01 PM
4g hatch's Avatar
this is the one i got. works good,i havent tried it yet on a ls head though
http://cgi.ebay.com/ebaymotors/Valve...motiveQ5fTools
Old Mar 8, 2009 | 01:05 PM
It will not work on an LS head without modifying it, ie. drilling a new hole to mount it with.
Old Mar 8, 2009 | 01:10 PM
1.5Slowmatic's Avatar
use a lisle spring compressor, they work good as **** and you dont need the ehad off the car, just gotta catch the valve, take a look here
http://d-series.org/forums/showthread.php?t=102307
Old Mar 8, 2009 | 01:11 PM
NAH2B's Avatar
yes you can install springs and retainers w/o removing the head.
just make sure the piston is at tdc for the cylinder you are working on and it will keep the valves from dropping too far.
Old Mar 8, 2009 | 01:25 PM
formervendor's Avatar
Banned
The Lisle tool is an excellent piece but do NOT expect the new springs to be so easy to compress... especially if you are not using air to fill the cylinder to hold the valves in place.
Old Mar 8, 2009 | 02:27 PM
This wasnt the question though.
Old Mar 8, 2009 | 02:32 PM
if you got a air compressor all u need is a hose like one from a compression tester kit that will thread into the spark plug hole and just let the air pressure into which ever cylinder ur about to change the springs/retainers on and it will hold the valve up
Old Mar 8, 2009 | 03:22 PM
patriot's Avatar
... use a general valve spring compressor tool like the one thats listed on Ebay.
Old Mar 8, 2009 | 03:51 PM
NAH2B's Avatar
how nice of you to take the time to point that out, thanks
Old Mar 8, 2009 | 04:03 PM
You're welcome.
You are also free to point out how much of an *** I am, but alas, I already know this.
Old Mar 8, 2009 | 04:47 PM
mar778c's Avatar
Community Builder
Community Influencer
I remove the spark plug and fill the chamber with rope then bring the piston up to TDC. This will hold the valves.
Old Mar 8, 2009 | 08:55 PM
Turbowa's Avatar
Make sure to use soft nylon rope as to not score the cyl. wall's.
I have seen people try to use the hard plastic stuff and it just won't work.
94c1v1cex
32
May 27, 2010 02:37 PM
mikebaglini
Nov 10, 2004 04:24 PM
InfamousDC2FI
Feb 6, 2004 10:41 PM
Speedz
Jan 7, 2002 03:22 AM
