ef obd1 block and obd0 head?
how would i go about swapping a b16 into my ef the block is obd1 and the head is obd0 is this a bunch of headache or is it worth it the guy is going to sell it to me for 675, please all help is appreciated
i am not worried about it bolting up i know thats not the issue
what ever would be easiest the car i dpfi so either way i have to get it converted and get a sub harness with vtec solenoid, so what one would be easiest or how do i go about this, i dont know much about mixing obd head and blocks
I didnt say that, COnvert it to mpfi then it would be readyto go as far as obd0. If you wanna go obd1 then convert it to that aftyer its mpfi hope that helps.
you'll need the grey plug obd1 b16 distributor, 4 wire o2 sensor and the conversion harness from rywire.com or such. That's about it.
if you convert it to mpfi then its all ready to go obd0 which I guess would be easiest. From obd0 mpfi you convert to obd1. One more step in the process plus the obd1 distributor new is around 2 bills. Obd0 you can use the stock o2 sensor and all.
alright i think ima sit this one out because it sounds a lil confusing lol thanks for ur help
if your switching and are ok with doing wiring just get a obd0-obd1 jumper harness. do not worry about injector clips as your will be fine. and the other guy is making things sound a little more hard then what it is. just read up on some other posts and do some quick searching
just swap u car to mpfi and slap the b16 with mounts linkage ect ect in the car its not that hard to do.
obd1 is for later use dont worry about it cause its not required
and u could always use the search button for dpfi to mpfi swaps
would those need to be obd1 or 0 thanks
i might give it a shot its to good a deal for me to pass up lol
If its your first swap you'll likely encounter things, expect there to be more downtime/costs than planned and have a bit of extra cash as a safety net.
any suggestions what should i have the connector as though is my main concern.. should i stick with ob0 what my car is or should i go obd1
u can buy the bolts new from honda not sure on the price but prob like 2 a piece or so
all in all man if ya have the money to buy that dpfi to obd1 i would, i went obd1 about 2 months ago and my car seams to run so much smother. granted i made all my harnesses
