Majestic honda/ Del sol DOHC engine wire harness CA emmissions bar for b16a
Does anyone know what the best Honda genuine OEM parts online store is i just know of majestic honda. Im looking for the cheapest. Im looking for the 1994 del sol engine wire harness DOHC CA car model. I own a CRX with a JDM b16a and i know that i need the engine wire harness from the 94 del so to bar my car im not really sure what the part number is or which one it is the drawing on majestic honda shows like 4 different wire harnesses im looking for the engine wire harness that goes from the ECU to all the TV sensors. If anyone has the exact part number could you please post it. I see theres a harness that goes for $881 and another that goes for $192. Not sure which one it is but im hoping its the cheaper one i need. I also know that its a pain in the *** to find the P30 USDM throttle body/intake manifold or fuel rails and all the smog equipment. Been reading some posts and my best bet is to go with a skunk 2 carb legal intake manifold and just buy all the components from an online honda store. I know that some referee stations accept jumper harness but the one in Goldenwest college CA will not accept anything of that. If anyone can help please do thanks.
If that guy doesn't like jumper harness, schedule next appointment at a different location. You have about 50 to choose from. Good luck.
For your B16a, you can also use the Skunk2 manifold if the USDM stock manifold is hard to find. Try the HondaMarketplace, southern california section and post a wtb ad there. I often saw people selling those rare del sol stock intake manifolds.
You will need your Evap Purge Cut solenoid valve and the PCV valve also, just get those for junk yard from 92-95 ex/si civic. I have a few of those lying around also if you can't find them.
Make sure you have the correct Cat converter with 4-wire O2 sensor. I don't know if the US Del Sol has the O2 sensor on the Cat, but the GSR does, so I just bought a Carsound Cat with O2 bung for $130.
I had stock GSR intake, so he didn't look twice. I had stock exhaust manifold with the factory heat shields, so he didn't bother.
LDO can i buy an evap purge cut solenoid valve and PCV valve from you?? Will it work with the B16a to get bar'd if so i would like to purchase them from you.
whyS0serious
May 25, 2013 08:13 PM
Benito89
13
May 2, 2011 11:41 AM
