h22 help
Old Mar 7, 2009 | 05:22 PM
jabatheonly's Avatar
Default h22 help
I just recently got a h22 swap into my 93 del sol .I am wanting to build it to about 260 to the wheels at a reasonable price and am wondering about ideas. I am thinking at the moment about exhaust ,cold air intake ,cam and port and polish. please give me some perspectives
Old Mar 7, 2009 | 06:54 PM
xenocron's Avatar
Default Re: h22 help
Take every HP you want to make, and multiply that by about $15-20 and start with a budget, and go from there.
Old Mar 7, 2009 | 06:56 PM
Damn if it that was that easy and cheap I would do it but I really want to get up to 260 at the wheels .At that cost it would be under 1,200 like im asking for so any ideas?
Old Mar 7, 2009 | 07:17 PM
h22ej8's Avatar
your h22 doesnt do 200 hp at the wheels, sorry.
probably 160-165ish if its not tuned at all.
so $20 x 100 = $2000
and keep in mind that's not even exact, it'll depend on if you go turbo, or all motor. If you go all motor its going to cost some $$$$$ to hit 260whp. You gotta pay to play, if you don't want to pay, then don't play.
Old Mar 8, 2009 | 04:06 PM
NAH2B's Avatar
to get 260 to the wheels you will need to increase the displacement of the motor.
here is a quick recipe that will work great for a dd:
95mm h23 crank
h22 rods
88 or 89mm pistons
12:1 compression
skunk2 pro1 or pro2 cams
skunk2 valvetrain
camgears
euro r intake manifold
70mm tb
you can retain the stock injectors and use the stock exhaust manifold to start with.
this setup will put you at least 260whp w/ plenty of tq as well.
if its strictly a race setup i would go w/ more compression, larger cams and definately a custom exhaust manifold.
Old Mar 8, 2009 | 04:11 PM
Combustion Contraption's Avatar
260hp for $1200 without Nitrous is a pipe dream.
NAH2B gave you some good advice, as did Xenocron with his $ factor.
Old Mar 9, 2009 | 11:21 AM
lunatics209's Avatar
check out this build
https://honda-tech.com/forums/showth...7260&highlight
https://honda-tech.com/forums/showth...1413&highlight
Old Mar 9, 2009 | 12:37 PM
117's Avatar
117
I don't think he was saying $20 for every extra WHP you want to make, so 260 * 20 = $5,200.
Although that cost estimate seems a tad low, unless you're not counting the cost of the ECU, tuning, and peripheral items for the engine (e.g. header, exhast, intake mani, throttle body, etc).
Old Mar 9, 2009 | 12:43 PM
117's Avatar
117
My main reason for not trying this setup is that I need the engine to run up to 8,000 ~ 8,200 RPMs multiple times per lap (for roadracing). Plus at TWS, on the front main I can top out my engine now (due to gearing), and the new engine would have to run over 7,500 RPMs for a good 10 to 15 seconds (I have to check my datalog to get a good time estimate). Would this be too much stress for a 95mm or 97mm crank in an H22?
95mm h23 crank
h22 rods
88 or 89mm pistons
12:1 compression
skunk2 valvetrain
camgears
70mm tb
delslow05
Jan 1, 2009 07:15 PM
dirtyharryhatch
30
Oct 19, 2008 04:05 PM
S2000 Lover
Dec 23, 2003 02:44 PM
SleepersOwn
Jan 13, 2003 01:26 PM
PorscheGT2
Sep 20, 2001 10:54 AM
