oil inside my distributor??
Old Mar 7, 2009 | 04:17 PM
blackeg's Avatar
Default oil inside my distributor??
never had this happen before, but im getting some oil inside my distributor. its coming out from the bottom where the cap meets the distributor and dripping on to top of my tranny. i know about the oring that goes into the head, but is there another seal i can replace? is it shot?
Old Mar 7, 2009 | 10:32 PM
mmuller's Avatar
Mad Scientist
Default Re: oil inside my distributor??
replace your distributor shaft seal; check the shaft for play since its most likely going bad
Old Mar 8, 2009 | 06:47 PM
blackeg's Avatar
i got my hands on another dist. from a friend today. throw it in tomorrow and go from there...
i also just got off the dyno with this motor and it didnt make crap for power considering the setup and its good compression numbers
Old Mar 9, 2009 | 11:47 AM
b21c1's Avatar
make sure you change the seal
Old Mar 9, 2009 | 12:21 PM
twentyhurtz's Avatar
ok, i have went through quite a few distributors, oil leaking from inside the distributor is the result of a bad seal inside the distributor that they do not make a replacement for, i have searched. The solution is a new distributor, and usually when this seal goes bad your distributor bearings are gone out too, resulting in a lack of power, and usually my tach would be all over the place. Get a new distributor.
Old Mar 9, 2009 | 07:14 PM
blackeg's Avatar
ok got a new distributor, cap, rotor, plugs and wires. car feels more responsive but i doubt it gained the 30 something hp to where the setup should be. i also went from bkr7e to 6e's
Old Mar 10, 2009 | 04:21 AM
anothersickhatch's Avatar
why would you go from 7's to 6's?
i remember when i had oil in my distributor. the dealership didnt offer just that one seal. i had to buy a new distributor.
Old Mar 10, 2009 | 04:32 AM
turboef90's Avatar
http://www.thepartsbin.com/repsite/h...l~reparts.html
TADA! took like 2 min to look up search.com
Old Mar 10, 2009 | 11:52 AM
scuzz's Avatar
Not to hijack, but thanks. I order a couple sets for spares.
Old Mar 13, 2009 | 08:48 PM
averyvm's Avatar
man I cant believe you found these. I was looking everywhere for these things
Old Mar 13, 2009 | 09:58 PM
mmuller's Avatar
Mad Scientist
all you have to do is read the #/measure the seal and find it... you can do the same as far as the shaft bearing
themiz816
Apr 28, 2013 07:16 PM
Cameron k.
60
Sep 25, 2012 07:19 PM
s0lefreshh
May 11, 2009 04:23 PM
blackmfoggie
Aug 23, 2007 12:09 PM
porsche997dc2
Dec 22, 2003 08:49 PM
