11.8:1 with toda cams
Old Mar 7, 2009 | 03:58 PM
DRtools's Avatar
Default 11.8:1 with toda cams
11.8:1 pistons on a 2.0L capable of supporting toda c's?
NOTE: highest octane we get is 91 so I can't over do my pistons.
Old Mar 7, 2009 | 06:55 PM
UncleD's Avatar
Default Re: 11.8:1 with toda cams
B19Coupe made allot of power using Toda C's, I personally think they are an over-looked camshaft.
Old Mar 7, 2009 | 09:19 PM
Uncle Dave's Avatar
We have Toda C in one of our track LS/Vtec engines with around the same comp as you they work great very good mid to upper RPM power.
Regards Uncle Dave
Old Mar 8, 2009 | 01:23 AM
DRtools's Avatar
Regards Uncle Dave
thanks guys, if you don't mind me asking, how much power did you put down?
Old Mar 8, 2009 | 01:50 AM
b19coupe's Avatar
Post Re: 11.8:1 with toda cams
222 Dynojet WHP on a 1.8. 11.5:1 compression, Hytech header blah blah blah:
Toda C's are still one of my favorite cams.
Old Mar 8, 2009 | 01:55 AM
DRtools's Avatar
Impressive. I don't want to start another thread about pistons, so I'm going to ask here instead. Anyone familiar with supertech pistons? http://jhpusa.com/store/pc/viewPrd.a...idproduct=3010
Old Mar 8, 2009 | 11:08 AM
racebum's Avatar
rumor had it that mahle was making them. however, you can buy the actual 4032 mahle pistons with rings from maw products on ebay for $380 in the "12:1" height which i say tongue in cheek since i have no clue what part combo made that number. do read the k20 thread before you set these up. in that thread and in my own experience .0035 PWC is too loose for that piston since it's coating keeps it cooler. the slap never completely goes away. mahle asks for .0025 to .0030 and i would highly suggest that the number falls between that range.
Old Mar 8, 2009 | 04:07 PM
Combustion Contraption's Avatar
Toda C's
b19coupe
SUPERTECH
El Pollo Loco
Old Mar 9, 2009 | 07:22 AM
JDM_rolex's Avatar
B19coupe-
Sorry but what exactly was your set up? i dont understand what blah, blah, blah is...lol.
instead of using the supertech, how are the RS machines ITR spec. These super tech pistons, can they be used with stock rods?
Old Mar 9, 2009 | 07:35 AM
DRtools's Avatar
Almost every after market piston can be used with stock rods. The rods just need to be modified by the machine shop for the ARP rod bolts.
And RS machines ITR spec pistons are 11.1:1?
WH0R3nEF9
Jan 7, 2006 08:17 AM
hqrcrx
Dec 10, 2004 06:48 PM
nvmyb20hatch
Dec 7, 2004 05:51 PM
JDM TypeR 307
Dec 29, 2003 02:13 AM
JDMchris
May 28, 2002 09:55 PM
