help!....del sol rear disk
Old Aug 11, 2002 | 10:54 PM
s73's Avatar
s73
New User
Default help!....del sol rear disk
i did a search, couldn't find anything on this topic....
Got my hands on a set of rear trailing arms w/ the hub, disk brakes...etc off a del sol.....i have no idea what year is the del sol. Just wondering if it would fit on a 97 civic ex. Are they the same as the 99+ si rear disk brakes? Do they use the same pads/Caliper/disks as the si? Which prop. valve should i use? I have been told that my stock one will do, but its better to get a Prop valve from a car with rear disks. SO which Prop. valve should i use? Si or del sol??? could i use the e brake cable from the del sol???
have any of you guys did a del sol rear disk swap into a 6gen civic yet?
well......any help on this topic would be a lot of help
Old Aug 12, 2002 | 06:59 AM
CHEETAH's Avatar
Default Re: help!....del sol rear disk (s73)
yes, will fit.
greg
Old Aug 12, 2002 | 01:44 PM
nwdave's Avatar
Default Re: help!....del sol rear disk (CHEETAH)
Maybe I missed it, but you did get those brakes from a VTEC model right?
Old Aug 13, 2002 | 05:01 AM
s73's Avatar
s73
New User
Default Re: help!....del sol rear disk (delsolguy)
yes, 94 del sol vtec w/ no abs, this is going to be swaped on a 97 ex 2 dr.
i need to know which e brake cable to use (the ones that come with the brakes can not be used, i think one cable is too short)
And what kind of brake hose to run.....do i use the 99+ si hose, or the one from the del sol would work?
are these cal/rotor same as the 99+ si???
thanks for the replys........please post a msg if any of you guys can give me any more info on this topic.
thanks
424racer
15
Apr 25, 2010 07:48 PM
Galaxy Si
Aug 2, 2004 05:44 PM
iwhichisme
14
Sep 5, 2002 04:57 AM
