Del sol rear disk swap
Old Aug 11, 2002 | 10:52 PM
s73's Avatar
s73
New User
Default Del sol rear disk swap
Got my hands on a set of rear trailing arms w/ the hub, disk brakes...etc off a del sol.....i have no idea what year is the del sol. Just wondering if it would fit on a 97 civic ex. Are they the same as the 99+ si rear disk brakes? Do they use the same pads/Caliper/disks as the si? Which prop. valve should i use? I have been told that my stock one will do, but its better to get a Prop valve from a car with rear disks. SO which Prop. valve should i use? Si or del sol??? could i use the e brake cable from the del sol???
have any of you guys did a del sol rear disk swap into a 6gen civic yet?
well......any help on this topic would be a lot of help
gmcuajo1
Jun 22, 2014 07:23 AM
509delsol
Nov 23, 2011 09:12 AM
Galaxy Si
Aug 2, 2004 05:44 PM
s73
Aug 13, 2002 05:01 AM
