Grounding Kits
I was wondering if anyone has one of these grounding kits installed such as the ones from APEXi and NRG where it is grounded from a central hub instead of a bunch of wires.
http://www.modacar.com/products/Hond...grounding.html
Not necessary.
Buy some 8-10awg cable, round end connectors, heatshrink and crimpers. Make your own and upgrade;
-Transmission to chassis.
-Engine to chassis.
-Valve cover to chassis.
Theres one more but I forget, but basically you can add as many as you want. Those grounding kits are unnecessary and add too much clutter to a bay. Right now im using those NRG wires that you posted, but not the whole kit.
-Engine to chassis.
Yeah, the set up seemed really handy and a little more cleaned up but using 6-8 is a little over the top. I'll probably just make my own because the ones that are on there are getting a little old and I'm having voltage issues. Also, there is a ground from the alternator, I think. I'll just do that though, thanks.
djjosehernandez
17
Jun 3, 2009 07:24 AM
