all motor/nitrous gsr dyno
Old Mar 7, 2009 | 11:29 AM
.CUBISH.'s Avatar
Default all motor/nitrous gsr dyno
this is a customers car i just finished up..
85mm gsr block
11 to 1 cp pistons
eagle rods
ported gsr head
skunk pro2's
rmf header
direct port dry kit
880cc injectors
e85
i tuned the nitrous through the injectors using the nitrous output on the s300
Old Mar 7, 2009 | 11:56 AM
Mini-G's Avatar
Default Re: all motor/nitrous gsr dyno
I love nitrous. Nice graph. What chassis is this in?
Old Mar 7, 2009 | 12:00 PM
.CUBISH.'s Avatar
gutted ek hatch...
should be a fun weekend warrior..
car is around 2100lbs
welded diff
twin disc clutch
carbon coated gears
235/60/15 mt radials
etc
car actually has 2 direct port kits on it.. this was only on one kit.. we are going to set it up with a progressive 250 shot in the next few weeks
Old Mar 7, 2009 | 12:07 PM
JDM JEFFREY's Avatar
nice..nos FTW
Old Mar 7, 2009 | 01:35 PM
GoldLudeRay's Avatar
so what was the power n/a
Old Mar 7, 2009 | 02:33 PM
integra82786's Avatar
.......damn
Old Mar 7, 2009 | 02:44 PM
DonF's Avatar
Maybe the "blue" line?
Old Mar 7, 2009 | 03:05 PM
.CUBISH.'s Avatar
lol..sorry i thought it would have been self explanitory....
blue= all motor
red= nitrous
Old Mar 7, 2009 | 03:19 PM
Honda_Noob42385's Avatar
Is the motor sleeved?
Old Mar 7, 2009 | 03:41 PM
.CUBISH.'s Avatar
yeah.. 85mm darton sleeves...
car should put out around 500hp on spray when we are done with it
Old Mar 7, 2009 | 03:51 PM
Combustion Contraption's Avatar
Power
Old Mar 7, 2009 | 03:52 PM
wow im very impressed
did the e85 help with the net gains?
i only ask cause im going n/a w spray?
are you running the e85 solenoids?
Old Mar 7, 2009 | 04:15 PM
.CUBISH.'s Avatar
yeah...there would have been no way to make the power it did on 93.. and to run race gas all the time is too costly.. e85 is about 1.59 a gallon here
the car is running a dry kit...so there is no fuel going through the solenoid
Old Mar 7, 2009 | 04:28 PM
very good thinking i never thought about a dry kit on e85
im so used to wanting to run a wet kit cause of pump gas
so it would be safer to run a dry kit on e85 cause of its octane right?
give alittle input on the dry vs wet on e85
Old Mar 7, 2009 | 04:38 PM
.CUBISH.'s Avatar
its just a lot more cost effective...car sprays a lot cleaner... and its easier for me to tune it
Old Mar 7, 2009 | 04:53 PM
Natural Aspirations's Avatar
Were any fuel delivery modifications other than a larger injector size changed to run the E85? I have it local and my 12.1 GSR would probably benefit but I am weighing the cost to gain benefit. Currently running a Walboro 190HP and 310cc RC's which I know the injectors will need upgraded. Would 440cc be a decent choice for a 210+ on E85?
Old Mar 7, 2009 | 04:54 PM
DC_Legacy's Avatar
OP, you mentioned using a directport and its a Dry kit. Is it a Dry directport, or are you using a directport with no fuelline or with the fuelline port on the nozzle capped off if using one of those injector insert nozzels?
Old Mar 7, 2009 | 04:57 PM
.CUBISH.'s Avatar
its running 8 single fogger nozzles on the intake manifold...
the car is running a 255 intank pump and 880cc injectors
probably going to add an inline pump and some injector dynamics 1000cc injectors once we hit it with both stages
Old Mar 7, 2009 | 06:57 PM
namewasdallas's Avatar
damn thats insane looks mad fun to drive
Old Mar 7, 2009 | 09:03 PM
C_Rock77's Avatar
Damn Fred.....that's cool as Hell! Bet that SOB is FUN to drive!
Old Mar 7, 2009 | 09:20 PM
fatboy1185's Avatar
Big Cat
Originally Posted by .CUBISH.
twin disc clutch
carbon coated gears
LOL i was thinking this is overkill until i read that there will be another kit being added!!! Eeek!
Old Mar 8, 2009 | 08:14 AM
93hondaboy's Avatar
damn you cubish yur at it again. i think i will be giving you a visit this week. cuz im not to happy with my tuned either way right now. my car made the same power on juice but on motor there something wrong with the picture 196 on motor and 330 on juice. it reminds me of my old motor and im like wtf this aint possible
Old Mar 8, 2009 | 10:08 AM
.CUBISH.'s Avatar
i got to play with the progressive controller and both kits...here's what we got to... fuel system is maxed out as of now
once we take it out on the street and track i can play with the ramp speed a little more... this was the only way to get it to hook on the dyno with street tires
Old Mar 8, 2009 | 10:29 AM
mar778c's Avatar
Community Builder
Community Influencer
Wow.
Old Mar 8, 2009 | 10:50 AM
d112crzy's Avatar
How many degrees did you retard at the beginning of the shot(first sheet)? I've found that if you retard about 8* per each 100shot and incrementally add it back in you get a much better mid range and you'll also gain some traction. Similar to what the 2nd graph looks like.
2nd graph looks awesome though.
I love nitrous.
