Motor Mounts, Is ITR vs GSR a different durometer?
Old Mar 7, 2009 | 09:41 AM
OH_1fstgsr's Avatar
Default Motor Mounts, Is ITR vs GSR a different durometer?
Item 12 in the image.
GSR part number 50841-ST0-N10
ITR part number 50841-ST7-Z00
I need to know if the ITR will reduce the engine movement over the GSR one that is going bad on my car. Plus the ITR one is cheaper.
Old Mar 7, 2009 | 09:51 AM
RockinaRHard's Avatar
Default Re: Motor Mounts, Is ITR vs GSR a different durometer?
Another non-ITR post.
Old Mar 7, 2009 | 10:09 AM
OH_1fstgsr's Avatar
I'm asking about the ITR Motor Mount.
I was under the impression ITR owners where very knowledgable about there cars. I figured this would be a quick answer for someone.
Old Mar 7, 2009 | 10:11 AM
best answer: all factory motor mounts go bad. get some aftermarket ones.
Old Mar 7, 2009 | 11:37 AM
Slo96ex's Avatar
The hell is a durometer?
Old Mar 7, 2009 | 12:09 PM
LudeEFv2.4's Avatar
My old title sucked.
Stop granny shifting!!!
Old Mar 7, 2009 | 12:27 PM
OH_1fstgsr's Avatar
Durometer measure of the hardness of a material.
The bushings in the motor mounts are made out of a specific rubber that has a durometer value. I am trying to confirm if the ITR is made from a harder rubber, higher durometer, than the GSR bushings.
Granny Shifting, not sure about, that must all the years of drag racing power shifts.
Old Mar 8, 2009 | 07:53 AM
jzak1's Avatar
should be the same. some people choose not to use torsion mounts with aftermarket mounts installed.
Old Mar 8, 2009 | 08:21 AM
OH_1fstgsr's Avatar
That's what I orginally thought, but when the part number was different I wasn't so sure. Plus the ITR part is about $5 cheaper.
Old Mar 9, 2009 | 04:28 AM
Devon M's Avatar
Go hasport! Ill sell you some for a good price.
Old Mar 9, 2009 | 08:45 AM
Dave-ROR's Avatar
It's a perfectly valid question for this forum. Your whole "This isn't an ITR question" thing gets old. It's not like he asked what the best suspension would be for his TL.
Old May 12, 2009 | 06:30 AM
JDogg's Avatar
anyone have an answer?
im replacing the mounts in my beater 4dr integra. I already replaced the rear mount with an ITR mount. Like the OP said its a little cheaper and a chance it might be better. I have to replace the 2 front torque mounts next.
This is my beater, I don't want the vibration of aftermarket mounts. When i want that i go drive my civic!
The ITR mounts are
50841-ST7-Z00 $31.94
50842-ST7-Z00 $31.94
The GSR mounts are
50841-ST0-N10 $37.35
50842-ST0-N10 $37.35
Old May 12, 2009 | 07:45 AM
Stinkycheezmonky's Avatar
Suspetise...
The ITR mounts are either stiffer or cheaper, or both. How can you lose?
Old May 12, 2009 | 08:24 AM
JDogg's Avatar
lol its true!
i'd just like to know
Old May 12, 2009 | 08:37 AM
99SlammedCivic's Avatar
Snipper Snapper
ITR adds horsepower - always go w/ itr stuff !
Old May 12, 2009 | 09:53 AM
JDogg's Avatar
Ballin! ill have the fastest old *** beater 4dr teg evAr!
lets see, i have the following itr parts
rear subframe
jdm rear sway bar
front LCA bushings
RTA bushings
rear motor mount
add the other motor mounts and this thing is gona FLY!
Old May 12, 2009 | 09:57 AM
Snipper Snapper
You win by default !
Old May 12, 2009 | 09:33 PM
robfrmny21's Avatar
itr mounts are lighter they look like swiss cheese when compared to gsr one they drill holes to make them lighter
Old May 13, 2009 | 11:10 AM
OH_1fstgsr's Avatar
I only changed one of mine out so far. I can take the new ITR and the old GSR ones to work and have them checked.
And no they are not drilled out. They look exactly the same except for the different part numbers of them.
Old May 13, 2009 | 12:03 PM
HYREV2NR's Avatar
Inserts are a cheap fix but,.... this guy^^^^ has the next (BEST) option.
Old May 13, 2009 | 12:08 PM
JDogg's Avatar
i dont want my junk vibrating so bad. It rides like a caddy, i wana keep it that way!
Old May 13, 2009 | 01:55 PM
donut.'s Avatar
Using common sense, the ITR would have to be the same, if not better. There's no way it could be any less. Furthermore, the ITR one is cheaper so you can come to the conclusion yourself on which one you should get. If you're concerned about stiffness, go with inserts or go with aftermarket mounts.
Old May 13, 2009 | 03:22 PM
HYREV2NR's Avatar
When I first installed my inserts I said OMG what have I done?! Now I can't think of not having them.
Old May 13, 2009 | 06:29 PM
Kike_Si's Avatar
^^^ True! Same thing happened in my Si. After a while I dont even notice that the dash trembles like an earthquake.
Old May 13, 2009 | 10:06 PM
HYREV2NR's Avatar
Yeah I remember the first time I started my R with the inserts, the motor was dead cold and everything that wasn't tied down rattled like crazy.
What's funny is my wife took it to the track to try out the new mounts that Friday night when I was at work. She red-lighted three times because it does make it a bit more responsive on the launch. The following week I didin't the same thing twice.
shockerjoe says
May 27, 2010 10:10 PM
dc4teg95
Feb 16, 2010 05:53 AM
Cheeks153
Sep 5, 2002 12:44 PM
