EG master cylinder leak
Ok so theres a fluid leak where the master cylinder meets the brake booster.. The black plastic covering on the booster is coming off and its kind of rusty looking underneath.
can i fix this? could it be like a gasket? Im just not sure what to do/buy. I found a whole used cylinder/booster combo for $30 so i was thinking of just getting that
or there was a new one for $31 for just the master.
well if it is the brake booster thats leaking, keep pressing the brake pedal with the engine off and it should get harder to press, if not then its probably the brake booster. or maybe its just a seal between your master cylinder and brake booster
integra123
Aug 8, 2006 05:52 PM
