Omnipower sway bar & brace kit
Old Mar 7, 2009 | 06:49 AM
bb_one's Avatar
Default Omnipower sway bar & brace kit
Hey guys,
I recently picked up the discontinued omni-power sway bar & subframe brace kit for 92-95 Civic & 94-00 Integra, and I am having issues with the install.
Basically the swaybar hits my aftermarket exhaust and will not allow me to mount the sway bar to the brace. The brace installed perfectly to the sub frame, but when I try to mount the swaybar via the "D" brackets, the swaybar contacts my exhaust.
Is this a known issue? Or did someone sell me the wrong swaybar, possibly for an EK civic instead? I've tried to search this topic, but it seemed like omni-power sway bar/brace kits were not popular. Tried to contact omni-power direct but have not heard back from them for over a week.
Any help would be greatly appreciated.
Old Mar 7, 2009 | 06:57 AM
Megalomaniac's Avatar
Default Re: Omnipower sway bar & brace kit
How extreme is the clearance issue? What is the OD on the exhaust, where on the exhaust is it hitting?
Old Mar 7, 2009 | 06:59 AM
bb_one's Avatar
Exhaust OD = 2.25"
It contacts the exhaust where it curves to clear the LCAs. Pretty extreme clearance issue, something grinding will not fix.
Old Mar 7, 2009 | 07:40 AM
really, really stupid question, that I hope you do not take as insult. Are you putting the sway bar in correctly?
I know it sounds odd but I've seen it done, a certain tech I know put the rear sway bar in upside down (with the hump running UNDER the diff instead of over it) on his own Excursion. It fit and installed and even worked other than making a clunk on cornering. Odd things.
Old Mar 7, 2009 | 06:49 PM
bb_one's Avatar
None taken, I also thought I could've put it on back wards so I tried both ways, both ways failed.
Old Mar 8, 2009 | 06:44 PM
bb_one's Avatar
Up for answers
Old Mar 8, 2009 | 08:31 PM
InTheZoneAC's Avatar
it's your exhaust. What brand exhaust do you have? Because most quality brands usually mimic the factory size/installation, but obviously the tip will be different.
Old Mar 8, 2009 | 10:41 PM
bb_one's Avatar
The tip? What tip are you referring to? If you are talking about the exhaust canister tip, then the sway bar mounts underneath where the exhaust piping curves to clear the LCA, not anywhere near the tip.
Old Mar 9, 2009 | 12:13 AM
Damaged Goods's Avatar
You might have to extend the exhaust piping a bit? I know that some people who got the WS II exhaust had the same issue with clearance.
justinwinn
Nov 25, 2010 04:31 PM
BOOST3DTEG
Nov 6, 2008 06:04 PM
Maireeka
Suspension & Brakes
Nov 12, 2007 03:17 PM
porch
Oct 30, 2001 06:16 PM
