Modified Brake Syistem on '93 Hatch
I bought a '93 Civic hatch for my all-motor project and the front and rear brakes seem larger than what comes from the factory. I want to buy new discs, SS brake lines and pads but need to know if these are Integra or Civic brakes.
Is there a simple way of identifying these brakes? Maybe the size of the discs or the part numbers on the arms, calipers, etc.?
What are the Integra swaps available as this information can lead me in the right direction.
Thank you!
Thank you!
current rotor size will let you narrow it down somewhat. if the rear control arms were used they may have a part number on them. any integra front and rear disk swap will go onto a 93 civic, you do have to change some stuff around but anything from a 90-01 can be installed onto an eg, the rear rotors on all of them are the same if i remember correctly so ordering rear disk brakes for a 97 ex, or a 94 integra will be the same. the lines are a bit different however in length, that was my experience anyhow. The fronts arent always exactly the same. i believe a few different years and espeically one type of civic model ha larrger front rotors and different sized calipers. remember reading it, just cant remember exactly what it is, its on this site somewhere.
