dose da susp fit egs?
Old Mar 6, 2009 | 10:04 PM
MugenManR's Avatar
Default dose da susp fit egs?
simple question or can i make it fit with slight modification
Old Mar 6, 2009 | 11:16 PM
HiProfile's Avatar
Default Re: dose da susp fit egs?
Does cutting and welding on the entire front DA crossmember & lca mounts count as slight modification to you?
In short, not even close. Only the knuckles would bolt up, but will really mess up your suspension geometry in a bad way.
Old Mar 7, 2009 | 10:21 PM
MugenManR's Avatar
i mean jsut like a coilover set up. My da has tunabe sustec pros, i bought them off a kid that once had them on his eg and they worked fine. i just wanted to double check too see if this was true
Old Mar 7, 2009 | 10:38 PM
-=ZAK=-'s Avatar
dc will fit but duno about da
uses0ap
Apr 8, 2009 08:05 PM
BOOSTEd2
Oct 6, 2007 05:28 PM
egzboy
Honda Fit
Mar 6, 2006 10:31 AM
